yeah well brad yours is a dream compared to my nightmare. even after 48 hours of burn-in I get errors in test 5 at a measley 230MHz at 3.5V. *$%*&£&!!!!!!!!!!!
mmm i get a few errors in test 5 at 255 using no more than 3.4v, ocz guys over at bleeding edge have tried recommending a few tweaks yet hasnt really improved anything for me, the tref made the biggest difference. I think I might try looping test 5 at 250 and see if that makes any diffQuote:
Originally Posted by pumbertot
tref???can you link me to the thread with tweak hints please mate?Quote:
Originally Posted by bradmax57
got to try something im not too happy.
try TRC @ 13 and TRFC @ 15.
CH liked those two a bit looser, BH can tighten them down more..
http://www.bleedinedge.com/forum/showthread.php?t=8093Quote:
three different settings, wether you have a newcastle, winchester or clawhammer
comparison with my BH :)
my suicidal screenie with 2 BH
not bad but 285-290 like my 9nda3+ in benchmarks....
my SS is missed with clockgen :p:
too fast...
http://cpull.free.fr/Overclocking/Ra...loverclock.gif
296 max is the best, same timings with my 9nda3+
I'll try with the 9NPA+
ive ran 255 2-2-2-5 for 8 hours, no memtest errors, 3.6V.
Tryed 260 same settings, and i got 1 error in a 3 hour test of memtest.
All other ram settings at stock, what do you guys reccommend? 3.7volts? Got dual 80mm fans over em.
Just got my VX 4000. They'll run at 254 with no errors in memtest. Hopefully they will hit 260 after burn-in.
I haven't been able to test mine yet, but I'll post my results when I get around to it...
BTW, I think I saw my stickers on there said 2-3-3-8...does anyone elses say that? I assume that's the rated speed for defaults, and the volts need to be applied before 2-2-2 is obtainable.
The stickers on the new kit that I received today say 2-3-3-8 PC 3200 Gold Edition VXQuote:
Originally Posted by isp
I guess that is for 2.6 VDIMM?
From reading over at BE they say the sticker represents the SPD to ensure that they boot safely. Can't remember the actualy post about that tho but it was confirmed by the OCZ reps and they assured everyone they're still rated at 2-2-2-8
http://img231.exs.cx/img231/9477/vx21oa.jpg
SS with my Vx Dc :)
maybe I can do 280 with the 1.36mod bios.
Gonna try tonight.
Edit:
Could pifast @273. 3,7volt i believe.
http://img220.exs.cx/img220/8498/273pifast1ia.jpg :toast:
Anandtech revisits OCZ VX
Just checked it out. Looks pretty much the same.Quote:
Originally Posted by SLaY3r07
Nice to see some comparison between OCZ TCCD at DDR636 2,5-4-3-7 and the VX at 10x267.
you all seen this ?
PC5000 Platinum
anyone got any ?
http://www.xtremesystems.org/forums/...ad.php?t=59086Quote:
Originally Posted by graham_h
Ok so I'm at 248MHZ on my pc3200 VX. I tried at 3.2V, no go. 3.5V no go, 3.4V no go. And just for the hell of it i try 3.3 and no errors? IS that normal? IS there some kind of frequency to voltage ratio anyone is aware of?
It's just like that sometimes.
I'm thinking of buying the Value VX for my p4 2.8c 478 p4c800-e system, does it perform any good on p4 ?
http://www.venomousmofo.com/mofo04/260vx.jpg
http://www.venomousmofo.com/mofo04/260vx3.jpg
Theres an example of what my Value VX does.. $150 well spent. 3.5V and i really havent even tweaked it. Wish i had a 10X multi on this crappy CBBID. It runs D20L stable now for 4 days straight.
heh, I'm kind of having some funky results with that too. "Less is more" :lol:Quote:
Originally Posted by Magnj
I burned mine in at 3.2v (2-2-2) for about 24 hours, and then I slowly worked my way up to 250 at 3.4v. Any voltage over about 3.55 I get a ton of errors in memtest (no matter what speed). I guess I'm not cooling them enough for that high of volts...
I'll play with it some more later to try and get it stable at high v, but for now they're looping memtest at 255 (3.4v).
I'm a bit carefull before buying these modules
2*256Mb pc4000 OCZ VX ...
After reading this thread, I dont realy know what to do ?
Everybody advices to run these modules at an DFI board but I'm using the MSI Neo2 Platinum...
Any info ?
jz got my booster, my corsair pc3500 bh5 manage to run 252 @ 2-2-2-11,1T @ 3.5v
They need volts to run tight timingsQuote:
Originally Posted by BerT
