Thanks for the pics.
to get more pressur :cool: . i know it looks not the best but it is the best i'm able to get it into my case. have simple to much blocks i think.Quote:
Originally Posted by Jupiler
heres one of my projects
http://i10.photobucket.com/albums/a1...ochest/028.jpg
dd dc 12v>xspc 1200m rad>dd tdx cpu/b>dd 5'25 drive bay res>pump
it dont look to good in the shabby case but a new one is cooming soon, i hope,
<a href="http://img379.imageshack.us/my.php?image=watercooled9xz.jpg" target="_blank"><img src="http://img379.imageshack.us/img379/3586/watercooled9xz.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Yeah,Quote:
Originally Posted by amduser
Saw the pics at HWLuxx.
Looks kinda weird, but as long as it performs well, then leave it that way. ;)
Look what arrived 2 days ago :
http://users.skynet.be/MetalHead/weapon/rarara.jpg
http://users.skynet.be/MetalHead/weapon/heatercore2.jpg
http://users.skynet.be/MetalHead/weapon/heatercore1.jpg
http://users.skynet.be/MetalHead/weapon/heatercore3.jpg
http://users.skynet.be/MetalHead/weapon/sanace.jpg
Crazy 4-way parallel loop:
Custom res -> Eheim 1250 -> '85 econoline van heatercore + custom shroud + polished aluminum 120mm L1A -> Storm/G5 -> Splitter ...
Splitter to:
Dual-Drive silenstar
Twinplex Northbridge
Twinplex Videocard
Custom VRM Block (not done yet)
All those recombine into the custom res again.
http://www.personal.psu.edu/mss26/ar...ath/39/006.jpg
http://www.personal.psu.edu/mss26/ar...ath/39/100.jpg
http://www.personal.psu.edu/mss26/ar...ath/39/101.jpg
custom res
http://www.personal.psu.edu/mss26/ar...ath/38/130.jpg
http://www.personal.psu.edu/mss26/ar...ath/38/133.jpg
crappy flash :(
http://www.personal.psu.edu/mss26/ar...ath/38/207.jpg
G5:
http://www.personal.psu.edu/mss26/ar...ath/38/208.jpg
Northbridge:
http://www.personal.psu.edu/mss26/ar...ath/38/211.jpg
Splitter: (goes from 1/2" ID to 4x 8mm OD/6mm ID, one unused as VRM block aint done yet :slapass: )
http://www.personal.psu.edu/mss26/ar...ath/38/212.jpg
Vid:
http://www.personal.psu.edu/mss26/ar...ath/38/214.jpg
massive 3/4" ID tubing for 1250 inlet:
http://www.personal.psu.edu/mss26/ar...ath/38/215.jpg
Silentstar dual HDD cooler: (houses 2 10K RPM u160 SCSI drives)
http://www.personal.psu.edu/mss26/ar...ath/38/216.jpg
Zee OC!
http://www.personal.psu.edu/mss26/ar...ath/38/401.gif
Nice, very nice. Btw, Bullit, I think it looked A LOT better with the Lian Li case instead of the CM Stacker. Just my opinion.
Usama aka Ferrari Freak
SD 3700+
DFI Lanparty-D 939
Gainward 6800GT
OCZ Value VX
MCW 6002-A64, Eheim 1048, BIX with Enermax 120mm, Innovatek Tank-o-Matic, Tygon R-3603, Antifreeze.
http://www.xtremesystems.org/forums/...id=36266&stc=1
http://www.xtremesystems.org/forums/...id=36267&stc=1
http://www.xtremesystems.org/forums/...id=36268&stc=1
http://www.xtremesystems.org/forums/...id=36269&stc=1
http://www.xtremesystems.org/forums/...id=36270&stc=1
Tim, that's a very organized and clean setup! Props!
I finally put a sidepanel to my case ending this version of my computer..
http://img387.imageshack.us/img387/3553/corner7ds.jpg
http://img387.imageshack.us/img387/786/side8uu.jpg
http://img387.imageshack.us/img387/4642/rad9kd.jpg
http://img387.imageshack.us/img387/7190/flash8zp.jpg
and a diagram of installation for RAD:
http://img367.imageshack.us/img367/7020/h2osetup4ef.jpg
Originally Posted by stardust
how much pressure is there on the rear of the mobo tray/fan mount with that rad mate? only curious as i was thinking of hanging a pa160 on one out the back of my pc65 as i wont be modding this case
Bacon,
The rad is holding up well. I don't know the exact pressure, but if you don't secure the tray to the case, it may bend slightly at the corner of the tray. I put in my motherboard after I attached the rad setup to the tray and it fit fine, so no warpage happened. The PC65 mobo tray is surprisingly durable and strong.
The only problem I have right now is taking the side panel off. I need to unscrew the tray from the case and slide it out about 1 inch before I can take off the side panel. I saw this problem in advance so I left extra length in the res-to-rad tube that snakes under my cpu block. If you look at my "teaser thread" you will notice the tray is slightly open and that tube is taut.
This is the first WC setup I did - about a year ago.
MVP-600 pump
DD RBX on cpu
DD NV68 on GF6800U
BIXII with 4x 120mm Pabst on fan controller in push-pull with a homemade plenum chamber in front.
Silenstar dual WC box for 2x HD's
Case padded with noisekiller mats
MCX 159 on NB (not pictured)
System also has 2x 24" Dell 2405 LCDs :D
http://home.online.no/~jaschjer/compinsides.jpg
My old watercooling:
http://home.scarlet.be/~gebrvd00/waterkoeling/10.jpg
http://home.scarlet.be/~gebrvd00/waterkoeling/11.jpg
Pump Bechkett G35 (60W):
http://home.scarlet.be/~gebrvd00/waterkoeling/08.jpg
CPU block D-Tek Whitwater:
http://home.scarlet.be/~gebrvd00/waterkoeling/05.jpg
And as last picture, my fan:
http://home.scarlet.be/~gebrvd00/waterkoeling/12.jpg
Biggest suprise: I was getting bad temps :confused:
Bad temps?! Wow, with a rad like that? Maybe a pump that can handle something like that is in order.
this pump can defenetly handle it. must be something wrong with the block I think
The pump is dumping about 3x more than heat than it should be. Get rid of it and get a pump more suitable for that application, like an Iwaki MD20RZT.
Oh go on then :p:
Here's my *nearly* completed project, just waiting on getting the front bezel painted silver. My full log is here if anyone wants to have a read :D
Once I'm finished I'll post some much better pictures for you all :) Here's how it looks at the minute.
http://www.aslr97.dsl.pipex.com/newdye.jpg
Mods include silver painted Hydor L30, re-tapping the Aquatube to 1/2", LED modding the blocks, custom polished Maze4 GPU and many more...check the log :D
Lights out...ish :p:
http://www.aslr97.dsl.pipex.com/newrunning1.jpg
http://www.aslr97.dsl.pipex.com/newrunning2.jpg
http://www.aslr97.dsl.pipex.com/newrunning3.jpg
http://www.aslr97.dsl.pipex.com/98002.jpg
open case, taken by a webcam at night.
Well, I finally gave up on the nf3 Ultra-D so I made the switch to the nf4 Ultra-D and PCI-E 6800GT eVGA from my AGP 6800GT eVGA card...anywho, I just got it set up last night and only let it bleed for about 30 minutes or so, hence the reason for bubbles in the T-line as it's not 100% bled yet, also sorry for the xtreme closeups, but my computer is in a tight squeeze so I'm not even aiming, just holding the camera about 8 inches away and clicking lol:
http://putfile.com/pic.php?pic=9/25117374143.jpg&s=x4
http://putfile.com/pic.php?pic=9/25117382334.jpg&s=x4
http://putfile.com/pic.php?pic=9/25117385374.jpg&s=x4
I was finally able to make a better turn from the graphics card to the T-line...my previous two setups had the tub coming from the right barb and making a weird loop which cause me to have to make a window in my sidepanel that extended off the sidepanel just to make room for the curving tube lol.
taken by a webcam.
here is mine case and watercooling system. http://koti.mbnet.fi/seriaali/vanha%20kotelo/Kone1.jpg http://koti.mbnet.fi/seriaali/vanha%...e%20kotelo.jpg
There is xp 1700+ palomino@ 1800Mhz and that graphic card is radeon 8500 le@ radeon 8500 retail.
MY new system
<a href="http://img287.imageshack.us/my.php?image=img00016gi.jpg" target="_blank"><img src="http://img287.imageshack.us/img287/6486/img00016gi.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Thermochill 120.3 with 6Xpanaflo
Swiftech MCP655
Acetal MAZE4GPU with 172 Watt peltier
Powered by Meanwell sp-480-15 at ~16.5V
Koolance CHC-A05 on NB
More pics here
http://www.hypernexussolutions.com/cinoxen/pc/24.jpg
http://www.hypernexussolutions.com/cinoxen/pc/27.jpg
My first case-mod, water cooling, phase change (built a few rigs on air though)
@Leeum - the interior of that case is just beautiful. you did a GREAT job on the aesthetics in that thing. this is about what i want my case to look like on the inside. so pretty /slur
@cinOxen - you did a marvelous job fitting that rad into the window the way you did. what kind of molding is that around the window?
