but i see that cards are there ?
did you try to remove the drivers really all ? i mean remove restart till unknown device are detected and the yes install ? or just fresh windows install, cauz i can see that 3 cards are recognized perfect
Thanks sergio, to see now change the combination, but still not resolved.
http://img18.imageshack.us/img18/597...rra3waysli.jpg
VGA: 580GTX MSI / 580GTX EVGA / 580 GTX EVGA, seems they all have to be the same Bios to work
No need to be same BIOS, just same models (all reference or all Direct CU or all Lightning).
I have 4 different brands and BIOS and running 4-way SLI.
http://img535.imageshack.us/img535/3645/4way.jpg
Maybe your tri-SLI bridge is not ok.
Samsung at 2133 9-10-10. This is the first chip that wont boot at 2400, so I tested 2133.
http://img864.imageshack.us/img864/2432/samyr.jpg
Uploaded with ImageShack.us
wow quite a dif on bandw from my current setup, could you do 1T ?
SB score way more but i still love the idea of 6 cores :)
here the sammys 2400 CL11 1.35v @ 2133 9-10-10-29 1T 1.55v
http://img41.imageshack.us/img41/5196/p1110687g.jpg
http://img715.imageshack.us/img715/8...391010291t.jpg
to the left patriots to the right samsungs
http://img854.imageshack.us/img854/1179/comparisont.jpg
Sergio, I had misconfigured external selector, which is 1-2-3-4 were mismatched, and the Bios too, were the two different configurations. There was an error. It was my mistake, not the motherboard.:p:
Thanks.
I am getting a lot of sag in voltage under load on this board. Is there a Vdroop setting I can disable? It seems to be evading me in my searches.
Edit: Found a setting of LLC that I am happy with, the higher settings really throw mV at the CPU and I was not really into it. But High seems to be a nice setting. Close to BIOS vcore.
My quick user review of Rampage IV Ex.
http://translate.google.cz/translate...38%26t%3D21663
http://img215.imageshack.us/img215/2576/malyzeshora.jpg
You may or may not have an ant problem in your computer after that :P
no problem, I tested it under LN2, its more danger than grass (I take board against the fence). Lol is, here is winter and in this city is not a snow :)
I have made user review too with some impressive results using only air cooling
http://h9.abload.de/img/1k0bgq.jpg
http://translate.google.cz/translate...38%26t%3D21639
Guys, what are the odds of reaching 5ghz with a 3930? Easy/common/fair/difficult ??
very difficult, but if you have wattercooling, its is possible. With air for 24/7 no chance (too hot).
My R4E arrived two weeks ago, but I was waiting for 3930K...
And it's here. :)
http://img99.imageshack.us/img99/696...21101small.jpg
Up and running. :up:
http://img855.imageshack.us/img855/6581/r4e3930k247.jpg
I'll be bothering you guys probably with stupid questions next few days, but forgive me, as I'm a little late in the game, cause it was very hard to come by this stuff here.
Welcome donmarkoni.:)
SB-E is fun!:up:
Nice hows it going so far Don?
cant wait for C2 dang !!!
For stability with 32GB RAM, is it better to have 4x 8GB or 8x 4GB sticks?
