@Dumo that close and still not the same vids! son of butch! lol
http://www.mediafire.com/?ngcgkgkklkn1u6m
There you go.
Will try, thanks Napalm:up:
Asus intalled plastic back plate which probly make it worse:(
I'm looking for new gpu pots, MM's gpu pots already out of date. Probly both cards will show their hidden power when naked and cold:D
Heres out of the box sli run with mismathed bioses..
http://img5.imageshack.us/img5/2307/screenshot088e.png
http://img263.imageshack.us/img263/3...enshot089h.png
http://img846.imageshack.us/img846/4...eenshot091.png
I got my Evga GTX580-SC a couple of hours ago and just installed it, stock VID is 1.082v which is pretty high from what I've seen from the rest. I guess 950Mhz might be very hard to reach or even 900Mhz ?
http://img641.imageshack.us/img641/4871/580x.jpg
Makes me thing bad batches are sent to my country :ROTF:
How much should be the maximum 24/7 voltage that can be pushed on stock cooling, say something like limiting the fan speed to about 80% tops, 1.100v ?
Nice results guys!
I am looking to get a GTX580. I saw where Giga will make an Soc version of the 580. They bin the GPU's for the Soc cards, so that seems to be the only choice for a guaranteed low vid.
Would it be best to wait for the Gigabyte, or does anyone know of another brand available in the US that has binned gpu's?
Also, there is a 480Soc available at newegg for 100.00 less than the reference 580. Is there that much difference between the 480 and 580 to make it worth spending the extra 100.00?
It will be used for 3d benches, not gaming. I need roughly 55k points in 05. Not sure if this is possible with a single card?
2 CUIIs retail samples from Newegg
The top one overclocked to 957 maxed (s/n 1213XXX) and the bottom one (s/n 1212XXX) can do a lot more with the same oc. settings...made me believe that same 580 CUII gpu will varies in term of oc on stock hsf.
http://img171.imageshack.us/img171/7...enshot084t.png
CUII #0 with base Voltage @ 1.00V at 1.15 VGPU
http://img43.imageshack.us/img43/631...nshot021od.png
CUII #0 with 1.80VGPU
http://img87.imageshack.us/img87/120...enshot023y.png
CUII #1 with base Voltage @ 1.013V at 1.15 VGPU
http://img251.imageshack.us/img251/3...nshot026jm.png
Dang.....I started binning this CUII:(
Nice, both cards have pretty low VID.. maybe nvidia is binning 0.995v chips as well ?
Haven't try your bios yet.
On stock air HSF oc this CUII really is a gamble (like I7 2600K), dunno if Asus binned it or not. Probly the one with high leakage, low air oc will shine when put it on cold:D
Imo the lower the vid, the higher the leakage. So, it can run on stock Vgpu?
My VID is 1.082 and its currently running @ 1.088 by default, would it be safe for me to lower those to say 1.050v or its already fixed to be stable at 1.082 at default clocks?
I wouldn't recommend Furmark (and similar) application at all, especially with OCP turned off. You could burn your VRM.
I've found an extended Heaven Extreme Tes run (like 30min or so ) with max AA along with Vantage (max res, settings, aa, resolution pending monitor ) with feature tests 3x loop and 3DM11 on demo + test usually shows instability. There are never any guarantees with this stuff but in my own experiance if a voltage / clock is unable complete all these tests, instability is likely. From there I simple do the things I normally do ( games, decoding / encoding etc. ) and if all is well you have your answer :up:
On a side note I've found Just Cause 2 to be quite effective at stressing hardware and ironing out instablility. Sadly There appears to be some inherent driver instablilty and it has ocassionaly crapped itself on me on more than 1 machine ( another with a 470 ) even at stock.
Any specific test to loop under Vantage?
How can I check if my OCP is turned on or ff?
Noted, Max Tes + AA under Heaven
Vantage Feature tests looped at max settings and 3DM11 demo
I want to perform some of these benchmark tests or synthetics before I go with my real world gaming test for stability.
EDIT:
BTW, how can the vantage feature tests be good since the down time inbetween tests is quite long.. its not really a single flow of different tests ?
Which game test on 3DM11 is very sensitive to overclocking, something that we can loop several times or so..
EDI2:
Initial testing for 1.000v I got 2 stable loops on 3DM11 Demo with performance preset, all sliders to max out side from MSAA which i left at 2x and running at 1680x1050.
