not better than my 965 ;)
Whats the cooling on that sucker?
If it's LinX stable... it's prime stable.
Then we got a trouble with my cpu ;)
Only a fast test :)
1.48v (real vcore)
Indoor temp... 25c
http://i674.photobucket.com/albums/v...3/4113Linx.jpg
Guess what
Itīs a phenom II 955 Black edition CACAC 0952!!!
and donīt forget C3 BRUTAL STEPPING!!!!
anyone knows if itīs a good week or not???
Rodrigo
newest stepping i have seen, just 3 weeks old ;)
I have seen a couple of articles mentioning a 95 watt Phenom II 955 due out soon, although the AMD site still shown 125 watts for the 955 C3 stepping.
I will check the box for a while
bye
This is my c3 965be passed blend 3 hours, upping 1.58v vcore on bios, 1.35v cpu/nb. Windows7 64bit
Temp is so high
http://img685.imageshack.us/img685/5638/4014.jpg
Hi guys.
I finally finished installing the new CPU...
first some questions.
I live in Brazil in Rio de Janeiro, itīs too warm and we are in summer.
I could get 3.888mhz stable with 1.4V and 2.6ghz NB speed.
My motherboard has a feature that I really HATE:
ITīs a Gigabyte MA-78GM - U2SH AM2+ ( i think ítīs not the best option for a high end 955 BE C3 processor...) the cooler automatically increases and descreases the cooler speed with the temperature of the processor...
imagine when my processor is reaching almost 70š C.
the cooler is at 6000 rpm. Maybe this could damage the AMD inbox Cooler.
PLEASE...
1 question)Is it normal? to have the cooler in this speed? almost 6000 rpm? Could this damage the INBOX cooler????
2 Question)
Will I have to wait the WInter to put my litle baby at 4.0 ghz????
cheers and waiting for some tips
bye guys
About the clocks
After I uninstalled the Program That comes with Gigabyte for Overclock.
The temperatures and the cooler speed are better now...
anoyone can help me ????:shrug:
Get an aftermarket cooler, the stock cooler will not be enough when overclocking, especially when you live in such a hot place.. :)
The fan wont break down unless you feed it more that +12v, which i highly doubt your motherboard will do.
You should be able to change it in the bios, so the fan keeps a set speed instead of auto adjusting depending on cpu temp.
GUYS... ITīS SOOO STRANGE...
NEVER SEEN NOTHING LIKE THIS...
WELL AFTER UNINSTALLED THE BOTH PROGRAMNS FOR CONTROLLING/MONITORING THE CPU.. EVERYTHING COMES TO NORMAL.
I THINK THE "AMD OVERDRIVE" AND THE "GIGABYTE EASY TUNE".
I think these programs act direct in the bios... itīs fu$@ing crazy.
Well after uninstalled everything was normal. CPU temps. went really DOWN.
like NOW.
I am running my Phenom II 955
CPU SPEED OVERCLOCKED : 3.8ghz
CPU VOLTAGE : 1.32V
CPU IDLE TEMP : 42 š C
CPU LOAD TEMP: 60 š C (running LinX)
Hey guys is it a good score???
I will push more this baby!!!:yepp:
:shocked::shocked::shocked:I can get the 4ghz from this little baby...:shocked:
I canīt believe It, linX stable.
Only 1.32 V
now i īm really afraid if i damaged the cpu or not.
with that crazy (past configuration), my psu was pointing 300W under load.
now with 4ghz under load it never passes 220w.
I was really afraid of how much voltage was being sent to the cpu...
damn... whats the maximun of the cpu can handle???
bye
wow nice clocks for those voltages. glad it worked out for you =) - my mobo defaults my chip to around 1.4v
Ļlastviking: whau nic, nice 955 C3 chips!Looks better than x4 965 C3. I seen, do u have 3x 955 C3?
This is my second 955. It's also a 0945MPMW. This is just a megahalem with a 110cfm panaflo, and a hr05 on the NB for the gd-70.
http://www.overclock.net/gallery/dat...100PII9552.PNG
