It's fixed but I think you could sustain DICE on the NB without overcooling the PWM. Is the PWM in contact with the HS or beside it? Must go look at board.
My wife just called and said the baord was in. Can't wait to get home, and I have a 2hr meeting after work too :shakes:
Simon, I have 2 HTPC's already :p: That will be easy. can't wait to get cracking.
So build one for your car :cool:
got mine :) thanks simon! got one last midterm today so should be able to put it through its paces tonight through the weekend.. i will probably do most of early testing on air with makeshift bench setup & then water testing will be in closed case (or something - just trying to figure out how i will do this w/out tearing my entire rig/loop down again, but we'll see :p: )
I missed that lol. Thanks.
Well, My wife was nice and emailed me some pictures for me. So here they are. Thanks Simon!!
http://3800z24.info/Phenom/890gx-box.JPG
http://3800z24.info/Phenom/890gx-board.JPG
Grats on the boards guys! I'm sure you guys will do some cool stuff with them.
Watching from the side line here. :)
Its fixed like simon said,
Is this the pic you need?
http://i271.photobucket.com/albums/j...1/P3180316.jpg
charged: u have new mobo?:)
If I misunderstood your game plan Simon you and others disregard this post?
Ok Simon if you want me to decide on the final test set to be used below is how I plan to do?
I do believe that the IGP should be tested along with the new chipset in order to showcase the new features.
I know each of us have posted a list of the tests we would like to use so now I ask each of the other five testers to submit just one test out of their own list. I plan to include one of my tests into the final set of test so at least three other tests will be included. I think four (five max) different tests should be enough to keep us busy. Let me know if you want four or five total tests?
I would expect everyone to post stock scores for each of the test as a baseline and then everyone could overclock as they wish and post results as they test. I think different cooling solutions will be employed which should make the results varied and interesting.
I hope I didn’t blow the word count again!:rolleyes:
thanks titan, i was hoping to keep the mosfet cooler on w/ the nb off, but no go. it looks to have been superglued/soldered to the mosfet heatsink.
chew's 3DMark2006 is 3200+. ill try to give it a go, if i can get 3Dmark2006 to run on an IGP. i've always had problems (3D wont even start). hopefully i figure out whats wrong(with the user that is.):ROTF:
hello little buddy!
http://i664.photobucket.com/albums/v...i/IMG_0951.jpg
http://i664.photobucket.com/albums/v...i/IMG_0953.jpg
http://i664.photobucket.com/albums/v...i/IMG_0051.jpg
Um, Simon, lol. My BIOS is in some other language and is visually distorted. Are you messing with my head. :p:
Edit: It is fine once I have the 5850 installed. Something is wrong with the HD4290. Anyone seen this before?
Edit: here is the pic
http://3800z24.info/Phenom/bios-huh.JPG
charged mine looks fine w/ 4290, you try reseating the cable? :shrug:
Looks kinda heiroglyphicky! :ROTF:
oh snap! +200 up from my previous score target!
im gonna have to use DICE on both 965BE + 890GX!
then i have a chance!
look what i found for the 890GX, an oversized toothbrush holder!
too bad its too big. oh well, simon siggested an artillery shell? :ROTF:
lemme see what i can find at the army surplus store tomorrow.. :up:
http://i664.photobucket.com/albums/v...i/IMG_0954.jpg
anyone been messing with theirs yet? whenever i change the sideport memory to anything above default 1333mhz it show up as 600mhz in cpuz graphics tab (wrong) and 800mhz in gpuz (wrong)... when i leave it at default 1333mhz it shows as 667mhz in cpuz graphics tab (correct speed) and still shows the wrong 800mhz in gpuz tab :shrug: anyone know anything about this? i need to test it some more but i think it still may be raising the sideport mem speed even though its not showing any changes
