Believe it or not, Wezly - I did actually consider that. The issue I have is there is virtually NO room behind the motherboard tray in this case (my major complaint with the case). SO, it could be done, but I'd have a rat's nest behind the mobo tray, and I'm trying to keep that area neat and tidy.
The PCI-E cables barely fit back there. And, as you can see, I cut my holes larger than I would really like them. In retrospect, I should have gone ahead and used a small hole, then re-attached the connector. Unfortunately, this isn't very practical for me, since I change components so often. (I've actually contemplated re-doing the mobo tray, but perhaps I'll just use this as lesson-learned and apply that to my next build).
:rofl:Quote:
I think that if shazza were to water her palm plant more often, it would make her midplate appear straighter.
