sorry mango, this was the latest.
try contacting evga direct and ask them about the status of your PSU.
good luck
I can boot with ~215 BCLK but the max I got so far with E-llet was ~223. More than that and my machine got totally unstable and BSOD :(
103-110 pcie? qpi compensation to less?
Yeap, pcie up to ~115. QPI compensation to less, don't remember the other configs.
Problem is right now is kinda hot in here so I can't do a good suicide test. I was also trying with the 21 multi only, I'll try with a low multi and see what happens.
CPU impedence to less and qpi compensation to less helped me lot:
http://www.upload.ee/image/193631/4483.JPG
My X58 SLI Classified (760) arrived tonight. Ripped it open only to see that EVGA dropped the damn ECP. Granted you can buy it for $20 but that still sucks. The board does look nice. :D
Anyone tried this new BIOS ?
http://kingpincooling.com/forum/showthread.php?t=131
Just want to know if the max boot bclk problem is fixed to flash it :D.
I flashed my 760 with that bios I the only test I was able to run was my signature oc (24/7) that was 10x Linx stable and now it's no more :(
I'll do a complete test this weekend but what I can say is that I saw some different bios options (not on the OC part).
I was able to boot up to 215 bclk as I said before, I'll see if I can do it at 220 or more.
what bios are you using Viper? i can boot 220 with bios618 havent tried higher. I booted my cpu on my rampage gene 226bclk.....
With bios 610 (I guess) I was able to boot from bios ~215. The new bios I'm using now is the one The_Game posted above:
760:
http://www.filefactory.com/file/ah9cfdf/n/IX58S630_bin
759:
http://www.filefactory.com/file/ah9cfe8/n/IX58S230_bin
758:
http://www.filefactory.com/file/ah9cf1e/n/IX58SZ30_bin
Is it impossible to make a GeFroce 6800 PCI-E GPU run on the classified mb?
When i try this it just crashes after booting into windows:down:
221
We need a boot-up bclk setting^^
you want my boot up for 221? 221*21 vcore 1.38 vtt 1.25 rest on auto
He means that we need the bootup bclk option available on DFI boards. You tried with lower multi or turbo off ?
okok...i tried with lower multi but didn't work....never tried with turbo of but if you want give med settings and i'l try.....
is it ok with cpuz i'll reboot. then you can ask what you want
It seems its a mobo limit :(. Too bad for that great board. I hope that evga will fix that with future BIOS, because it can be a limit for gulftown...
