awesome results macci :toast:
you continue to set the standard (no matter what CPU is in your hands)
Cheese n Rice! Macci those are brill results. Ever planning on coming to South Africa for a holiday and tweaking my system for me? I`ll buy u all the beer u want (after the mod that is).
Hey guys, especially you macci: how come no one here is really playing with the FX-51? Is it because it is a too expensive of a cpu to mess around with or what?
macci is it me or does te 3000+ just oc better than the other a64s or you just got lucky :D well i seen opp get over 3ghz with his too but you guys are using mondo cooling.. -- Which is the best cpu to mess around with if you have phase change cooling and money is not an option? Thx.
I've just clocked my a64 3400+ to 2670 but with mem divider.
When I use 1:1 my Mushkin lvl2 PC3500 wont go over FSB 235.
When I raise the vdimm from 2.98 to 3.20 it gets worse. Can it be that I have to raise the vbt or something?
If so, can anyone please link or show a picture of where to measure the vbt.
Seen the mod at Maccis homepage, but cant see where to measure.
2670 was done with 1.84v and LDTx2
EDIT: 2700mhz with mem at 220mhz cas 2 2 2 6.
Just want to be able to do 1:1
Is 1:1 much better than with an divider? Or is that not so important with the a64 anymore? :confused: :)
It would be helpfull to tell wich board you're on.... :)
Oh Sorry forgot about that. I'm running on a Gigabyte K8NNXP.
i think its because of the ecc memory...Quote:
think i need badly this moboQuote:
Originally posted by macci
Gigabyte K8N Pro
my epox and abit seems to be the limit now on my 3400+
just with geil 4200 not my mush the epox don't like my 3500 bh5
http://www.tweakers.net/ext/f/23164/full.jpg
on xtreme air but my prom 1 and prom 2 on 507 will not get higher.
so i need other motherboard
Cant get any higher with either a mach I or a mach II, you defo need a new board then.
Yup get the K8N-Pro, im getting one for a A64 3000+ im getting ;)
How are people getting so high on the FSB with asus k8v mobos? the highest stable i can get is 225fsb x10 @1.5vcore. After that it corrupts my HD. Using a seagate SATA HDD on the via SATA controller
s-ata is your likely the problem. try ide.
peter any hdd corruption> are you using a 66mhz pci card?
well i had the gigabyte k8nnxp before and it would not oc at all with my khx4000 1:1 ratio. guess it does not like cas 3 mushkin bh-6 did fine though
whats so good about the k8n...
does very high fsb...stable as hell ...does not kill as many cpus as the an50r :)
this is the most stable OC i can get
temp is 55C Idle on stock cooling
i lost mounting hardware for my waterblock new set got shipped be here friday
need a vcore n vmem volt mod to go any higher
memory crashes @ 270
prime crashes after a second if i do 2.45 or higher
more volts needed!!
thinkin' of gettin' radioshack part #278-017 to do the vmodds n the 47k pot
http://users.rcn.com/trackstar2001/267.JPG
soccrstar,
Very nice! With the mods and better cooling you could really kick some ass!:D
:toast:
Awesome!
I am thrilled to see so many people using the a64's
w00t!
lets all keep our cpus for atleats 6months guys lol :D
now thats impossible :DQuote:
Hey... I've just got my Shuttle AN50R mobo' - But can it be true that i can't overclock with ClockGen? I can't press the "Clocks" button... Whats wrong?
you need to BURN-IN your hardwareQuote:
or else it will FAIL.
i learned that the hard way and had to RMA my cpu n mobo
I think its only for the Via chipset, check the clockgen's website and make sure you downloaded the correct version.Quote:
Hmm... Okay... I'll try to find out of something ;)
Damn. It is'nt supported for my mobo' :( Do any of you know another clock program to the CPU?
I use it all the time on my AN50R, make sure everything is on auto in bios, except for LDT (set it to 2,5), Vcore and Vdimm.Quote:
Make sure you have the version for NF3 mobo's.
GL.
Weird... My nForce3 drivers has really gived me alot of trouble... In the start i could'nt start op in win when i've just installede my drivers... Så maybe i have to re-install windows?
