So far so good. 704m Runs and benches fine on my Deluxe board. I'm going to see how high I can push my Q6600 on the FSB.
Why do you think I busted out my BIOS modding tools? :p: I was all too well aware of Asus pulling crap like this, and tbh when I bought the P5Q Pro it was around £100 before postage, so not exactly cheap for a mobo. Asus especially have very poor comprehension of that lower-mid highend boards will net them the most money. I have only ever ONCE bought an uber board - Asus Crosshair, BUT, it just looked fancy. Didn't exactly have anything I hadn't seen on other, CHEAPER boards. Now with my skills applied to BIOS 703\4\7 (depending what mobo you own) the board I have at least has never clocked better. 1206MHz memory frequency rock stable, before nomatter what I modded any BIOS that had that pesky CPU Margin Enhancement I couldn't crack 1066 stable even though I could boot much higher frequencies (1200+)
The 0704 was a little slower for me so , I figured ok maybe more speed then but, nope. I couldn't boot into 495 x 8 but, I could 490. I went back to 0803 I get 5ns better lats with it. Thank you though Ket :up: .
Its just as I said somewhere in this thread, everything is subjective, what works for one may not work for another ;) I may find myself flashing up to 1307m again once I get a wolfie, but in the meantime I'll keep my 1200MHz+ mem frequency :D
703m on my P5Q-PRO resulted no POST with OCZ2N1066SR1G. ASUS crappy memory support..
I'll look at 901 beta for the Pro, if theres no CPU M-E, I'll mod that one up for people to try. Which mem slots did you put those SR1G sticks in?
Ket, Just wondering if you, or you no of someone, who can supply a modded BIOS for the Asus P5K Premium that would improve the memory frequency steps? Thanks...
So which BIOS is currently the best for a P5Q Pro and a E7200?
Try 1307m, if that doesn't quite work out try 703m.
you think that 703 is better than 1307 on my comp result of 1307 is more than 703:) this is old 0703 right? there still is problem with core temp on Q6600 i think that 1307 is better on my com:)
buy the way wen you are planing do the uber bios? you told that you are starting working on it :) so what this uber bios meens? what is uber bios? i'm sure that it will be realy good but can you tell me please what is uber bios and when you planing finish it? :)
thank you
you are the best :0
Hey Ket I made this tinyurl to point people to this thread who ask about my BIOS. Maybe ya'd like to use it as well.
http://tinyurl.com/moddedp5q
Mmm... BIOS 704Mm is causing some odd issues were the BIOS does not retain settings... I'll look into it a tad further.
Additionally, no matter what OCed settings I use, it won't boot. Back to 1306 I guess.
Any idea why the P5Q will NOT overclock with half dividers? I have the P5Q Deluxe and an E7200 - runs at 400x9 fine and even runs at 445x9 fine, but 9.5x400 is a no go - it posts but windows just instantly bluescreens. Put the divider to an integer value and all is well...
Edit: I'm using the 1306 Factory BIOS, currently.
So just to be clear 1403 does or does not have the Premium memory table, the one which "pisses all over the M2F", I've been running your 1402 and like it for it's stability and mainly because I can finally use NVFlash. I take it 1403 also sees NTFS partitions? Oh and by "your kind of memory" I gather you are rferring to Cell Shock's or D9 modules. Lil ol me is just running some budget Gskill DDR2 1000 2x2GB, in your opinion would I be better served by the M2F or the P5Q Premium table? in other words 1402 or 1403 I'm itching to upgrade the bios why I don't know, it's a disease I guess. Whats really funny is that it's 99.9% certain that by the time I get a reply I will have updated to 1403. lol
Thats very strange. By the looks f your setup your system may be one of the ones that prefer a BIOS with CPU M-E.
Theres a known issue with half multis with the P5Q series, Asus are aware of it, if they fix it or not is another matter.
I'll release it when I get chance to finish it, at this time there is no ETA.
If 1402 is working good for you and all is well, no real point it messing and "disturbing" your system ;)
Its confirmed to the point Asus are aware of something odd going on :p:
my 7.5 multi works fine, but there is no 6.5 multi for me :shrug:
(e8200/p5q)
Just flashed to Ket's modded 704 BIOS for the P5Q-Deluxe...very nice. My Redline 2GB sticks are currently Priming at 528MHz (DDR2-1056) at 2.1v. They needed at least 2.2v to get up there with any degree of stability. I like! :D
I really appreciate the work you're doing on these BIOSes. If you have a PayPal email address I'd be happy to toss you a small donation for your effort.
Sage advice, but as predicted by the time I read it I had already flashed, and I'm doing well, whether it's the bios or that I just hit on some better settings but I've eeked another volt less 1.21 in Bios 1.2 actual and PL7 pull outs enabled vs 8 on 1402 Intelburntest stable. I actually booted into windows with my ram @ 1066 but my linpacks were off(didn't crash however) So I likee. Nothing earth shattering but a nice reasonable 20% and I get to keep my fans real quiet. I did test stable 500 FSBx6 earlier so I could get a whole lot more out of this I'm sure but... I'm happy for now. Thanks Ket
