I had to set them in BIOS first and then boot, you cannot change NB in AOD, yes NB was at 2940 HT@ 2700 ish....
18427 3DMarks
SM 2.0 Score 7521
SM 3.0 Score 8456
CPU Score 5125
seem kinda low for 3.75ghz and 2.5ghznb HT 2250mhz vista 64 bit too.
maybe it's my two 3870's, they're not OC.
big difference in XP CPU score here was 5584 with CPU @ 3.78.. see post #532....
hmm... i may boot into windows XP and let it run.. brb
edit:
http://www.abload.de/img/3dmark06vq7j.jpg
same overall score as in vista x64. lower sm2/sm3 scores and way higher cpu scores. maybe i should download cat8.12 for xp to.. this was done on cat8.9
UPDATED:up:
also i have limited access to the internet right now so can you include as much info as possible so i can check the link then copy/paste your info. I dont rely on futuremark for system specs it doesnt say if cf was used incorrect cpu clocks etc. etc. so please if you want yours listed help me out:D
example:fact:
Nice runs guys :up:
I've been trying to get a score in earlier, but the 79-T is a bit tempermental.
I gave up and switched to 78-T last night
3DMark06 21488
SM2.0 score 8331
SM3.0 score 10485
CPU Score 5770
http://service.futuremark.com/compare?3dm06=9616074
Phenom II 940@ 3960 MHZ(240x16.5)@1.5875v
M3A78-T(bios701)NB@2400 HTT@2400
CF 2x 4870's 750/900
4GB (2x 2GB)@960
Win XP sp2
Cat 8.12
I just put in my 940.
9950 (3.4) 18488 ---- At 1920-1200, 4aa, 16af, 18091
940 (3.4) 19680 ----At 1920-1200, 4aa, 16af, 19140
I'll crank it up more in a couple of days.
A personal best but I think it will go up..testing high HT multis still. Voltage is off the charts I know but was messing around at 4.0ghz+. Unable to complete 06 runs at 4.06(failed boot) and 3.9(incomplete)(12x and 12.5x). Still alot of fun. :yepp:
Total Score - 20883
SM2.0 Score: 7914
SM3.0 Score: 10443
CPU Score: 5534
Phenom II 920 @ 3.74ghz 325 HT multi x 11.5 cpu multi
Biostar 790gx a2+
2x1Gb Patriot PC6400 @ 867mhz 4-4-4-12-21
Radeon 4870x2 @ default
http://service.futuremark.com/compare?3dm06=9622607
*updated*:up:
Well i need to get back up to my spot #5 on the list. Phenom II 940@3.690 , 4 HIS 3850 (256)@715/950, ATI 8.12 drivers, Vista-64 home basic
SM2 7892
SM3 10918
CPU 5087
score 20858
http://service.futuremark.com/compare?3dm06=9635537 well the 3850s are still hanging in there .One of the thing that make me most happy is scoring 132 FPS score for canyon flight (test of crossfire) that staring to get the job done for 3850s
nice work merkk1 you got those 3850 screaming:rofl::up:
Thank you Msimax
If i just could get the cpu to clock up to 4 mhz i think i could put the hurt on Ben heheheh.
Merk: Run your ram UNganged, I had mine 940 @3.7 with NB@2900, score 5584 on 3dMark06, You can BEAT him,,,,lol......like I said UNganged and you should be able to OC the chip some more, also if you could run your ram @1066, would help
Sapphire HD4850
3DMark Score 13454 3DMarks
SM 2.0 Score 5014
SM 3.0 Score 5681
CPU Score 5584
I give it try again (unganged) but what i seen so far that didn't help also try 1066 vs 800 i get more NB and HT link speed with the 800 and so far it keep edging out running 1066 . The 1066 memory dose 1066 but that about it .As soon as the clock speed hit 3.7 cpu tell me to F-off and died hehehe .
3DMark Score 21239 3DMarks
SM 2.0 Score 8159
SM 3.0 Score 10575
CPU Score 5563
http://service.futuremark.com/compare?3dm06=9646832
PhenomII 940 @3.8GHz 2.6GHzNB
2x2GB Mushkin DDR2 @1066MHz
Sapphire HD4870X2 @800/965 ccc overdrive
WinXP
3D Mark 06 --- 21741
3744ghz (1.475v)
NB 2500
Vista 64
Still can't figure out how to print the 3D Mark screens.
3dmark06
940BE 3906Mhz (217 x18)
2604Mhz NB
2x 3870's 512 850/1220
3DMark Score 20014 3DMarks
SM 2.0 Score 8130
SM 3.0 Score 9382
CPU Score 5388
http://service.futuremark.com/compare?3dm06=9647236
Bump in NB/HT/GPU Clocks
3dmark06
2821Mhz NB
2x 3870's 512 860/1230
3DMark Score 20117 3DMarks
SM 2.0 Score 8185
SM 3.0 Score 9438
CPU Score 5395
http://service.futuremark.com/compare?3dm06=9647370
Ok Thank You HondaGuy for making me rethink what i was doing were on the move again .Phenom II 940 @ 3.735, 4 HIS 3850 @715/950 ATI 8.12 driver, vista-64 home basic .
SM2 8036
SM3 11102
cpu 5185
score 21,230
http://service.futuremark.com/compare?3dm06=9647332
Holy crap, all the scores are above 20k now. :p
Thanks chew*
[QUOTE=merkk1;3581489]Ok Thank You HondaGuy for making me rethink what i was doing were on the move again .Phenom II 940 @ 3.735, 4 HIS 3850 @715/950 ATI 8.12 driver, vista-64 home basic .
SM2 8036
SM3 11102
cpu 5185
score 21,230
No problem there Merk.....BTW should try ATI drivers 8.10 :yepp:... the newer driver is just way to buggie
