How much and where and how i/we can get one if need to be?
My 2-cents...I have had systems with high OCs that pass all of the available benchmarks including all 3D benchmarks and P95 for 24 hours. Load up UT2004 and play, system locks up within 10 minutes, or less. Bump vcore a smidge and all is well. I will no longer go for ridiculous P95 times. I will run all 3D benchmarks first to get a clue on what the OC will be then run prime on small ffts for about an hour. If it passes then it is off to the most stressful game I can get my hands on. I guess I should go out and get crysis or the new UT for testing.
Bios Chip sales you must talk in PM please they have busted my balls once already:D because I had it advertising in my siggy new rules coming down on forum lately:)
SHAWN,
have you tried putting the areca card in slot 1 and your VC in slot 2?...i did that with the original bios without any aux. 5/12v power and it worked just great..8x bandwidth for the areca card and 16x for the VC...posted and booted fine and i was able to access the areca bios during post regimen.
have you tried the above with the newest bios?
i found the areca card will get higher burst speed at 8x bandwidth over the 4x slot.
anyone has tried such settings ?
FSB=400
333/1066 (5:8) that means DDR2-1280
200/667 (3:5) that means DDR2-1333
my mobo hangs up with this settings on C1 and whistle...:D:D
@ ACE......Hows you're ARECA Raid Controller working in this motherboard please:)
esau can test xfire in the 16x adn 4x slot i was thinking of getting an areca and wanted to see numbers with pci-e2 and a pci-e1 4x
PCI-E 2.0 does not do much in terms of performance because the cards can't utilize the Bandwidth headroom right now not the way they will in up coming GFX Cards releases:D
You'll get about 800mb Burst in X4
I did that with the original bios as well, it worked. I have not tried with the newest bios, however, so I couldn't tell you if it still works or not. Maybe if I am bored later tonight I'll try it out.
I have tested with it in 4X and compared the results with the results from *x and there was no change at all. I plan on adding the 4th Raptor this weekend, so I will bench it in 4X and see what happens. If what Brother Esau says is true, which I believe it is, and I can see up to 800mb burst speed in 4X, then I don't honestly think 8X will be any better than 4X for the 4 Raptors I will be running. Who knows, though, I try it out and let you know. Thanks for the info guys!
Code:CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Enabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................10x
CPU Clock.................................266 MHz
Boot Up Clock.............................Auto
DRAM Speed................................Auto
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................Auto
CPU VID Special Add.......................Auto
DRAM Voltage Control......................1.904V
SB Core/CPU PLL Voltage...................1.510V
NB Core Voltage...........................1.265V
CPU VTT Voltage...........................1.211V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................110
CPU GTL 0/2 REF Volt......................110
North Bridge GTL REF Volt ................110
DRAM Timing Page
Enhance Data Transmitting.................Auto
Enhance Addressing........................Auto
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................Auto
RAS# to CAS# Delay (tRCD).................Auto
RAS# Precharge (tRP)......................Auto
Precharge Delay (tRAS)....................Auto
All Precharge to Act......................Auto
REF to ACT Delay (tRFC)...................Auto
Performance Level.........................Auto
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................Auto
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Auto
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................Auto
DIMM 1 Clock fine delay...................Current[14]
DIMM 2 Clock fine delay...................Current[5]
DIMM 1 Control fine delay.................Current[9]
DIMM 2 Control fine delay.................Current[7]
Ch 1 Command fine delay...................Current[9]
Ch2 Clock Crossing Setting................Auto
DIMM 3 Clock fine delay...................Current[13]
DIMM 4 Clock fine delay...................Current[3]
DIMM 3 Control fine delay.................Current[2]
DIMM 4 Control fine delay.................Current[4]
Ch 2 Command fine delay...................Current[10]
Ch1Ch2 CommonClock Setting................Auto
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
Clock Fine Delay At Work
Still very early into my testing of how memory behave on DFI LP LT X38-T2R with 11/28 bios. It basically seems like a more matured version of what is implemented on DFI LP UT P35-T2R :)
Playing with 2:3 divider (266/800) and 2x 1GB Crucial Ballistix PC2-8500, I found myself hitting memory clock wall at several points while doing my routine Memtest86+ v1.70 testing.
Only salvation to break through that memory clock wall was fine tuning Clock Fine Delay values for DIMM 1 & 3. To my surprise I broke through that 651Mhz wall and ended up at 666Mhz 5-5-5-9 at 2.49v being single Super Pi 32M stable!
- 633mhz 5-5-5-9 at 2.27v was okay
- 640mhz 5-5-5-9 at 2.31v was okay
- 651mhz 5-5-5-9 regardless of vdimm used kept freezing in test #5 loop testing - clock fine delay was all set to Current.
- 651mhz 5-5-5-9 at 2.38v errored out in memtest, but elimated freezing by increasing dimm 1 + 3 clock fine delay values from Current (2) to manually set 3.
- 660mhz 5-5-5-9 at 2.45v was okay in memtest now by further increasing dimm 1 + 3 clock fine delay values from manually set 3 to 5.
- 666mhz 5-5-5-9 at 2.49v would error out in test #5 loop on 2nd pass with a few errors everytime, no voltage adjustments helped.
- 666mhz 5-5-5-9 at 2.49v was okay when i further increased dimm 1 + 3 clock fine delay values from manually set 5 to 6 or 7.
- 670mhz 5-5-5-9 at 2.49v would error out in test #5 loop on 2nd pass with a few errors everytime, voltage adjustments didn't help much to stablise it. Dimm 1 + 3 clock fine delay values manually set at 7 helped reduce it to a few errors in memtest86+ v1.70 test #5 loop.
So here's where I end up at so far 666Mhz 5-5-5-9 at 2.49v! Pretty awesome for initially having hit a brick wall at 651Mhz 5-5-5-9!
http://fileshosts.com/intel/DFI/DFI_...cpuz_valid.png
http://fileshosts.com/intel/DFI/DFI_...3m20s110ms.png
http://fileshosts.com/intel/DFI/DFI_..._bandwidth.png
DFI LP LT X38-T2R Bios Settings
PC Health Status
Adjust CPU Temp: +7C
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: 8x
- Target CPU Clock: 3552
CPU Clock: 444
Boot Up Clock: AUTO
DRAM Speed: 266/800
- Target DRAM Speed: 1335
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.2875
CPU VID Special Add: AUTO
DRAM Voltage Control: 2.49
SB Core/CPU PLL Voltage: 1.51
NB Core Voltage: 1.643
CPU VTT Voltage: 1.377
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
- Enhance Data transmitting: FAST
- Enhance Addressing: FAST
- T2 Dispatch: Enabled
Ch1 Clock Crossing Setting: More Aggressive
- DIMM 1 Clock fine delay: 7 (manually increased from 2 allowed me to pass 651Mhz mem clock wall in memtest86+ v1.70)
- DIMM 2 Clock fine delay: Current 7
- Ch 1 Command fine delay: Current 11
- Ch 1 Control fine delay: Current 8
Ch2 Clock Crossing Setting: More Aggressive
- DIMM 3 Clock fine delay: 7 (manually increased from 2 allowed me to pass 651Mhz mem clock wall in memtest86+ v1.70)
- DIMM 4 Clock fine delay: Current 6
- Ch 2 Command fine delay: Current 11
- Ch 2 Control fine delay: Current 6
Ch1Ch2 CommonClock Setting: More Aggressive
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto (where cpuz sees 1T or 2T SETTING)
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 5
RAS# Precharge (tRP): 5
Precharge Delay (tRAS): 9
All Precharge to Act: 4
REF to ACT Delay (tRFC): 30
Performance LVL (Read Delay) (tRD): 6
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: Auto
- Channel 1 Phase 1 Pull-In: Auto
- Channel 1 Phase 2 Pull-In: Auto
- Channel 1 Phase 3 Pull-In: Auto
- Channel 1 Phase 4 Pull-In: Auto
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): 14
Rank Write to Read (tWTR): 11
ACT to ACT Delay (tRRD): 3
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 4
Ranks Read to Read (tRDRD): 5
Ranks Write to Read (tWRRD): 4
Read CAS# Precharge (tRTP): 3
ALL PRE to Refresh: 4
So how is this board compared to the P35 , or it is to early to make any conclusions?
I have 2 questions ... EVA ... how did you get the Everest beta version1227? I have the 1226 version, yet I can't find the one you have ...:confused:
Two, does anyone know why in the BIOS under Advanced Chipset Features > PCI-E compliancy mode ... it shows the version to be 1.0a ? I thought it was supposed to be 2.0 ... anyone notice this? :confused:
EVA - re your post #562 ... you say you did that with Crucial Ballistix PC2 8500, yet your CPU-Z shows OCZ PC2 6400 ... I have 4GB OCZ PC2 6400 and a E6850 ... if I use those settings, I should see something very similar to yours, right?
So its working then/ whats the Burst rate that you are getting?
hey BRO...does DFI boards have a serious problem with a lot of bios chips dying on flash???
How about this thread gets back on topic.
Not that I am aware of ACE but sheet happens you know? I just had a Flash go bad on me not long ago my Floppy drive threw a rod in the middle of the Flash and it was Good Night Irene:D
Sometimes too the Flash doesn't go right for what ever reason even if what you did was flawless thats happened to me a couple of times the Past year maybe bad chips who the hell knows:shrug:
But the Point is that its better to spend a couple of bucks on insurance so you don't get caught with you're pants down as RMA for Board takes 10-14 days vs a few minutes to plop a new chip in.........:D
just a Q and a quick answer wanted. would you guys that had the P35 LP recommend selling and getting this board or is it not worth it yet?
I am liking what I see so far, but I am far from being an expert, but right now I have it purring along pretty good ... it's been stable for most of going 4 hours at (9 x 423 MHz)= 3.8 GHz. Memory is stable as well ... I know this board has a lot more in it and I am learning as I go along ... and having some fun ... :up:
http://img529.imageshack.us/img529/7...at38sd2.th.jpg
