6.10.52 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
6.10.52 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
6.10.53 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
Edit:
OS X
OS X command line version
6.10.54 beta:
Windows 32 bit
Windows 64 bit
Edit:
Linux 32 bit
Linux 64 bit
Edit:
OS X
6.10.55 beta:
Windows 32 bit
Windows 64 bit
Linux 32 bit
Linux 64 bit
Edit:
New recommended version for OS X:
OS X
6.10.56 is recommended now for all platforms.
Version history: 6.10.19 - 6.10.56
* New: Updated localization files
* New: Added accessibility support for advanced view (Mac)
* New: Added support for parsing username and password information from environment variables
* New: Added ability to ignore specific GPU cards through the use of ignore device through the use of a configuration file option
* New: Added ability to suspend BOINC's use of GPUs when certain applications are run through the use of a configuration file option
* New: Allow new screen saver options to be configured via the OS specific configuration screen
* New: Snooze GPU option off of the system tray menu
* New: Adjust GPU activity settings via the advanced view activity menu
* New: Added ability for a project to be specified as a "Backup Project" by setting its resource share to 0
* New: Suspend computation of BOINC applications if CPU usage from non-BOINC applications exceeds a volunteer defined value (Defaults to 25%)
* New: Support detecting SSE2, SSE3, and other forms of advanced instruction sets for older Windows machines (Windows)
* New: Support for custom installers to automatically cause new accounts to join a specific team when atteching to a project for the first time (Windows)
* New: Support for Nvidia Fermi cards
* New: Added support for 'Transfer at most X Megabytes every N days' preference
* Fix: Name resolution issues (Mac)
* Fix: Activity Menu display issues (Linux)
* Fix: Reduce CPU load in dealing with communications between manager and core client (Windows)
* Fix: Properly display project descriptions on Windows XP machines in the attach to project wizard
* Fix: Numerous CPU/GPU scheduling fixes
* Fix: Numerous work-fetch fixes
* Fix: Mac Installer for non-admin installs
* Fix: Recover from crashes in Nvidia and ATI GPU functions (Linux, Mac)
* Fix: Reap child processes spawned from a wrapper on Posix systems (Linux, Mac)
* Fix: If a project supports ATI or Nvidia projects, display their icons in the project list
* Fix: Show most commonly used preferences in use during startup via messages.
Watch the settings when installing. I noticed that the installer didn't recognize my previous settings (no screensaver) or folders (not default). I'm running Windows 7.Quote:
6.10.57 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
6.10.58 beta:
Windows 32 bit
Windows 64 bit
OS X
6.10.58 is recommended now for Windows and OS X
6.11.1 beta:
Windows 32 bit
Windows 64 bit
OS X
6.11.2 beta:
OS X
6.11.3 beta:
Windows 32 bit
Windows 64 bit
6.11.4 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit:
Linux 64 bit
6.10.58 beta:
Linux 32 bit
Linux 64 bit
6.11.6 beta:
Windows 32 bit
Windows 64 bit
OS X
6.11.7 beta:
Windows 32 bit
Windows 64 bit
OS X
Edit:
Linux 32 bit
Linux 64 bit
6.11.8 beta:
Windows 32 bit
Windows 64 bit
6.11.9 beta:
Windows 32 bit
Windows 64 bit
OS X
Edit:
Linux 32 bit
Linux 64 bit
6.12.0 beta:
Windows 32 bit
Windows 64 bit
Didn't had any time to follow the new releases, but here they are:
6.12.1 beta:
Windows 32 bit
Windows 64 bit
6.12.2 beta:
Windows 32 bit
Windows 64 bit
OS X
Dude Sunfire, you are simply awesome.
From the first day I joined, you already been posting latest updates for all the patches and beta. I just wanna thank you for the help and dedication! :up:
Thank you lkiller123! :)
6.12.4 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Edit2:
Linux 32 bit
Linux 64 bit
6.12.5 beta:
Windows 32 bit
Windows 64 bit
OS X
Edit:
Linux 32 bit
Linux 64 bit
6.12.6 beta:
Windows 32 bit
Windows 64 bit
Edit:
OS X
Linux 64 bit
Edit2:
Linux 32 bit
