Holly Smokes man!....... :eek:
45nm Sweetness :D
Congrats and Good Luck for 28K, Kinc :)
Impressive clock Kinc, then new chip it's :shocked:
Tried OC with air/h2o ?
Yes it can do ~4.15GHz quad core on air.
More info here: http://www.nordichardware.com/news,6863.html
excellent scores out of that chip Kinc :eek: keep it up
hiya kinc on a side note hows the asus maximus formula doing as i am torn between the formula ddr2 or ddr3 extreme one , any insight
cheers
It is great. Gives you 2.3V for the cpu and ALOT of volts for the rest of the things you might wanna play around with. It clocks the cpu and memory high. Very good intreface for setting memory timings. Cooling is great, I love that they have separated the heatpipes between mosfets and the chipset. And ofc Crossfire perf is the best I've seen.
you can't say fairer than that, what would you say the performance difference between the ddr3 and ddr2 board 1-2% something like that i fancy the extreme board but it would mean dumping by old friends corsair cas3's and sinking some serious dosh into some ddr3 ram which if the performance difference isn't massive between them the formula edition would be a more economic choice
thanks kinc yes i think ddr3 is the way to go but currently its so darn expensive even for non hi performance ddr3 atm
Nice to see the "real one" storm right in. Congrats on the insane scores! :up:
That CPU looks 'ok'. ;) Actually I am VERY impressed of how much you gained with it. I do think there are plenty of WRs that are going to be broken this autumn.
The pi is just sick.. its no use for kentsfield anymore. Yorkfield here I come!!
Holy Moly that 05 is impressive.
Excellent work Kinc, yes we all want to see what a 45nm does on 2001. Please spend a little time with this.
I would think 03 would be pretty good as well even with Ati not being favoured of course in this bench.
Hey, although this is a 3D benching area that SuperPi 2D test is pretty good also :up: Bet you were blown away by that session ?
:toast: :toast:
Regards
Andy
Wow!!!:eek:
Not bad start Kinc!!!:shocked: :clap:
Incredible scores!!!
You're not CPU limited!!:p:
Congratz!:clap:
That's Xtreme Kinc!
Bravo! Very nice result & very nice sys
:clap: :clap:
Soon 28k + 300k + 7,9sec? :p:
Great scores Kinc! Looking forward for next weekend ;)
I wont' start new thread for this, but just started my own Radeon HD 2900 XT CrossFire benches with QX6850 and Asus Blitz Formula. CPU with dryice cooling and graphic cards with stock cooling, 3DMark06 23677. Managed to overtake Fugger and gprhellas:
http://service.futuremark.com/compare?3dm06=3179247
Nice benching :D
