6320 retail
6320 retail
Realtek 889A codec drivers, ver. 1.71...nice to see constant updates from Realtek:
http://www.realtek.com.tw/downloads/...&GetDown=false
My system in my signature... Having troubles with overclocking... Every time I think I have a stable overclock, the computer will just randomly turn off, I will run orthos for hours... And then for no apparent reason, just reboots, even though orthos showed no errors...
Any ideas?
It just depends on the processor.
As soon as I mounted my Prommi FSB wall raised to 395 stable, 400 dead-end.
Think I will go for a different chip next weekend.
http://de.geocities.com/prignozert/e2140/3200.png ... http://de.geocities.com/prignozert/e2140/1m_high_s.png
P35c-ds3r and E6300, 443fsb seems to be highest that i can do with this, it will freeze computer after that 6x or 7x so maybe thats the limit, F3b bios now, havent tested others if they help but i doubt it. Dunno if i lapped it badly but even now with tuniq tower 120 it gets +80c full load @ core temp / tat, lots of other software says ~15c less.
If it matters on this but some ppl say core temps shows 85tjunction but mine says 100.
Nice board anyway, havent got any problems yet :up:
maybe, because after installing 163.11 it doesn't freezes while shutting down any more instead the monitor goes blank but the computer is still on
ı do 480 fbs 12 and more hours stable with +0.2 mch voltage and +0.3 fsb voltage and f3b bios
figured out the mem divider issue. I had subtimings manually adjusted and board likes them left to auto, at least for my memory.
I can run now 450fsb at 1:1 memory default mch, fsb, pci-x voltages, and I think default cpu voltage. However anything past that gets hard. 475 posts bios but nothing past. Even 6x multi. I took off NB heatsink and applied paste, no help.
Going to try some 6300 cpus I have lying around. Think I'm at cpu limit :(.
Re: NB Heatpipes. Were rev 1.0 based on the 90nm process as stated by Anandtech? Rev 1.x is 65nm, runs cooler and no longer needs the heatpipes? If it was just to make more room for larger HSFs, they could make the heatpipe shorter instead of replacing it with a standard Heatsink.
You should probably use a different program than memtest as it doesn't always register instability. My G.Skills would give random reboots but memtest wouldn't show any errors even after 11hrs. Orthos would only run for a minute or less before giving errors.
Not saying Orthos is the best choice but it's a start.
C2D E6850 @ 4ghz 500x8 1.5vcore (intel stock heatsink)
Gigabyte P35T DQ6
2x Kingston HyperX DDR3 @ 1500mhz 9-9-9-24 2.0vdimm
1gb HIS ATi Radeon X2900XT
Non tweak Windows XP sp2
PI 1m
http://forum.lowyat.net/index.php?ac...post&id=262029
i will definitely try 32m after i install my wc.. but for now the max stable PI for 1.5vcore 4ghz is 4m..
can someone teach me how to upload pic faster? coz in my local forum i use high reso pic .. and i'm afraid if it's too big for here..
I have a big problem,i bought a p35 dq6 impossible to assemble it the Vcore>1.525,in the bios information it is written "VCORE FAIL" but on my p5b deluxe
the cpu is more stable at 1,65 without problems.
Nedd some help please.
Hey guys,
Under full load my NB goes up to 63C according to Everest, this is with FSB @451 and +0,15v. It seems a bit high to me but then I don't know how accurate this temperature reading is. What temps are you guys getting?
