Originally Posted by JargonGR
I will probably order from them if the current cooling solution I use is not sufficient.
Overclocking Update:
FSB 411,VCORE 1.6250v, CPU @3.7Ghz 3 hours Orthos Stable (E6600)
They certainly need to release a new bios since I think the board behaves strange with certain voltages as well here is what I mean
With those voltages its rock solid @ 3.7Ghz
VTT 1.5v
NB 155v
SB1.6v
Hyper 1.4v(max as of now)
DDR 2.4v
NB DDR ref 0%
DDRref 0%
However funny things happen if I increase the FSB and there are certainly holes
FSB 427
CPU @3.85Ghz with 1.6050 1.5min Orthos
with 1.6150 2min Orthos
with 1,6250 most stable can play games for an hour but Orthos crashes it
up to 1.7250 eratic behaviour some good some bad and some voltages will not boot at all. What I mean is that there is no sign of the CPU clearly indicating higher or lower setting at this FSB it just crashes sooner or later.
The same from ,15250 to 1.650v
But I guess its the FSB.
I will try 440 and will post findings later but I am afraid that my CPU is maxing out at around 3.8Ghz so we will see.
