Originally Posted by PanteraGSTK
I hadn't put the HR-05 on yet. I did that last night. Install was easy for nb and sb, I just had to position them just right. For some reason my pc still won't go past 30 seconds of orthos blend. WTF? It doesn't matter if it is stock settings or 3.4ghz. Why? Is there another issure I'm missing? This sucks, I hope I diddn't waste money on those HR-05's when the NB wasn't my problem. However, I did turn the nb voltage to 1.75 last night to run an orthos test and I stopped it just short of 8 hours, so maybe that's not my problem, because it usually rebooted itself before that.
Another odd thing happened. I lapped my cpu and pressure mounted my infinity with a push push config (two fans perpendicular to each other) and my temps aren't all that much better, but I think that is because the AS5 hasn't settled yet. Also, the OC in my sig is no longer possible. It won't boot at 500fsb any more?:mad: What did I do wrong? If this continues I'll be putting my S3 back in and RMAing this sucker.
EDIT: Just thought of something. Could warping my motherbord have anything to do with not booting to 500fsb any more?
