If you have a 6800 you may want to try this.
Set 200 reference, set 533 for the ram (3:4) and 333fsb for the CPU. If you have good memory you should be able to set 4-4-3-8, TRAS dead low will actually hurt performance.
Now with the 6800 you will set a 12 multi for 4GHZ or 11 for 3.6+.
Access latency will be somewhere around 6ns faster in this config than running the ram 1:1 even if you are running well over 900 1:1 in 1067ref mode.
Im trying to source a 6800 to test here, im stuck with a 6700 so 10 multi is all i have but I have some data i can share.
Goldmem pro used for bandwidth, everest for latency.
Code:
memspeed FSB REF Strap ratio bandwidth latency
833 333 267 4:5 4736 61.4ns
833 311 200 3:4 4639 55ns
888 333 200 3:4 4965 51.5ns
888 355 267 4:5 5041 57.6ns
CPU speed was manipulated with the strap to force given ram speeds, even though 4:5 267 REF at 888 had the highest bandwidth its access latency is no where near as good as 888 200REF, which will make the 200REF setting faster.Now I know the CPU would be faster at 355fsb but we are looking at the memory here not the final CPU speed.
Remember C2D does not need tons of bandwidth, it just needs to use the bandwidth more efficiently. Lower access latency = more performance.
Tony
