701 beta up. Anyone tested yet?:stick:
On ftp.asus.com there is a newer one 706.
Haven't tried them out.
Hey anyone teste 0706 ?! Anything better than the previous one ?!
is it possible to use 2 different raid0 on this mobo?
2x400gb seagate sata2 raid0 and 2x74 wd sata raptor raid0?
tia
Hey guys a new dumb thing I discovered. You can have a front panel headphone/audio out that is on an entirely separate channel, ie., a new device.
If you go into the SoundMax preferences you can enable it, and then you have a new device in your sound settings. Kinda cool if you want to run mp3s on your stereo/speakers and use your headphones for gaming.
Or you could run Internet radio somewhere else with some long cords I guess.
Asus says the only fix in 701 is for not detecting the chassis fan...not really worth an update that.
Wonder what 706 does...
I have a question for everyone, What are the things I need to do to make this board boot to windows as fast as it can, with out overclocking or causing too much heat buildup?
on a side note, I dont want to overclock, but im getting a huge urge to as I read posts on this forum. Im nervuos to try really, guess im affraid I might damage something. hehehe This is a really cool forum by the way. I wish I knew about it a long time ago.
Oh Oh, one more question. How do I get the best FSB speeds out of this board as well, it seems people are getting lower speeds then they should?
Yep, Nvidia drivers also show it in 1x mode and, as i said, my 3dmarks are almost exactly half of what they should be.Quote:
Originally Posted by JoeBar
guys may be this will help u..........Quote:
Originally Posted by Ibna
set PCI-E to Auto when you are facing the 1x problem
i set it to 1X and then confirmed with clockgen, the PCI-e was still @ 100 Mhz. Buggy bios causing the 1x issue. Now, setting to Auto fixed it.
Regards,
Karan :woot: :woot:
706 fixes:
[ 0706 ]
1 Enhance CrossFire performance.
2 Enable NVIDIA 7950GX2 display under crashfree mode
3 Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4 Fix memory display message not correct under multi-language
5 Add Kentsfield B3 uCode
Originally Posted by Mr.Bones
nice! I may have to get this board now.
Yes with new 6.9 Catalyst.Quote:
Originally Posted by Devious
Vdimm info !!
I moded my P5B Dlx ( complete ) and is ok. But I set 3V to ram and mobo dead :slapass: Anything : cpu, mem, gpu .. is ok, but asus is dead complete. When I set 2.85-2.9 vdimm is ok, but 3V is too high for this mobo.
Be carefull when set vdimm !!
At least your memory survived.Quote:
http://www.anandtech.com/video/showdoc.aspx?i=2837
I haven't experienced this prob and i've used all availble volt options.Quote:
Thanks for the info! :)Quote:
Hi,
is there any windows based flashtool for the P5B? Maybe Winflash works? :)
Hi guys..i need help with my p5b deluxe and my OCZ Gold GX XTC PC5400
pc can't boot with the OCZ but with a 512Mb of Vdata (awful) 533 the pc run all ok!!
i tried with some bios, 2 official and 2 beta..but the pc is died...
I tried with a single memory but nothing..and in all slot available..
my configuration is:
E6400
P5B DELUXE
OCZ GOLD PC 5400 4-4-4-12 http://www.ocztechnology.com/product...00_gold_gx_xtc
and less importants...OCZ 520W, X1900XTX...and liquid cooling
I'm tired and sad, ASUS has disappointed to me!!!
thanks a lot anyone help me.. :D
P.S. pc don't boot...the monitor is black..thx ;) but with Vdata boot perfect
asus update on the disk
Thank you! :toast:Quote:
Originally Posted by loc.o
Anybody getting random system restarts? Mines restarting while running Orthos fine :(
If you mean when booting yes, everybody :D
hi gyus
sorry if my question has been already told :)
i want to ask if there is a program that can change the vcore into windows
Ps:I have eist,c1e,tc1,tc2 etc disable from bios ..
thxx
RMClock ?
Vdata requires maybe 1.8V.Quote:
Originally Posted by most_wanted
Up your ram voltage with the Vdata stick till 2.2V, try one ocz stick in the same slot (shut down the pc first ;) )
Nah, mine double reboots everytime I reset, but this is just random restarts during normal operation. More of a stability issue. Weird thing is it will run SPI 1M fine to about 4450, but just does these random restarts if I leave it running Orthos even down as low as 4150. Temp is only +2c under load and voltage seems stable, only drooping .02 from idle.Quote:
Also, I don't have the "Intel speedstep tech" option under the CPU configuration menu in Bios. This is with 0614
I was having the same problem, system were stable for Orthos run, but it would restart during normal Window operation. Then the problem sort of went away after I increased the NB voltage to 1.65v.Quote:
Originally Posted by Nico
