Originally Posted by eliwide
I know I am a bit late into this discussion but I am having serious problems with the DS3... My system powers on for about 2 seconds, then powers off, then keeps repeating this cycle until I pull the cord... The only thing that moves inside the case are the system fans (not the CPU fan), and the LED works but no signal to the monitor...
The only way I can stop it from turning on and off is if I disconnect the 4-pin power supply to the CPU, but then it ain't going to post, but at least the power stays on constant... By the way, I have tested the PSU seperately and it works without a problem...
I tried everything from resetting the CMOS, taking the battery out, swapping the memory modules around, disconnected everything to connect it again but finally gave up and decided RMA the board.. I like the board, so decided to ask for a replacement, but now I am wondering if I am going to land myself in the same situation.. Does anyone have any suggestions in case they just send back the same board?
From what I have read, I am guessing my problem is down to the fact that my board has an older bios or I am using dodgy memory... If the retailer just sends my old board back without updating the bios, what is my best solution?
The system:
CPU: E6600
GPU: EVGA 7600GT
MEMORY: OCZ 2 x @ 1GB 1.8V DDR2 667MHz
Thanks for any help
