Nice core clock.Quote:
Originally Posted by VL125
Mine is orthos stable and 13s 1M.
E6300 440FSB on air, keep in mind the Patriot PC5300s are runnig at ddr 880 2.1v
http://valid.x86-secret.com/show_oc?id=129818
Here is what I got my E6400 to on air - :toast:
http://static.filefront.com/images/p...vlznmsrpzz.jpg
Nice info shot TGE! Mind if I borrow heavily when the time comes?
Not really, 12.1xxx can be achieved with only 4.0GHz for Conroe with the right ram tweaks :)Quote:
Originally Posted by funkflix
Please show me a screen of it, included Memset! :)Quote:
Originally Posted by alpha0ne
Hehe. :DQuote:
Malficar E6600 @ 3.6 GHz Prime Stable (1.47v)|Scythe Ninja Plus Air Cooling|AW9D-Max (Beta Bios 1.3)|Mushkin XP2 6400 @ DDR 800 (4-4-3-4)
Click once to load and once to enlarge:
http://img281.imageshack.us/img281/6...inaldj1.th.jpg
Best Pi1m I do @ flat 3.6 DDR 800:
http://img183.imageshack.us/img183/1...bestyr8.th.jpg
pi32m 3.6 GHz DDR 800:
http://img206.imageshack.us/img206/1...i32mkw7.th.jpg
I can bench all the way up to 4.0 GHz and I am only including Orthos blend results @ 8 hours of testing. I did 3.7 GHz for 1 hour and 39 mins then had an error. I will try for 3.7 stable @ 8 hours plus again later.
4.0 GHz SuperPi1m Score (RAM 5-5-5-15 here):
http://img183.imageshack.us/img183/3...4ghzfg4.th.jpg
kingcars - E6400 @ 3.2GHz, dual SuperPi 32M/Orthos 1 hour 40 mins stable, 1.32vCore | Arctic Freezer 7 Pro | Gigabyte 965P S3 w/F5 BIOS | Patriot 2GB DDR2 667 RAM @ DDR2 800 5-5-5-15
http://img.photobucket.com/albums/v1...thosstable.jpg
http://img.photobucket.com/albums/v1...erpistable.jpg
I still want to fix the RAM timing problem and see how low I can set the vCore.
My E6700ES @ Aircooling
http://s3.bilder-hosting.de/tbnl/8MZ7G.jpg
http://s3.bilder-hosting.de/tbnl/8N531.jpg
Regards
SPLMANN
a member of www.overclocking-team-switzerland.com
hi
here is my spi 1M result on my wc E6600 on P5B deluxe (bios 0711):
http://metalazz0.free.fr/4005-wc-E6600.png
vcore 1.7V
VNB 1.65V
ram synch 4-4-4-10
L629, not so good :/
Also posted in the P5B best overclocking BIOS screens.
A jump in cpu voltage was need over 3.5ghz, but tonight i will be shooting for 520x7 = 3.64Ghz. That will be my final 24/7 overclock aim as load temps are reaching mid 50's, but that is with the tuniq fan at only ~50% :eek: :D
3.57Ghz stable (510x7). This is with 1.525V in BIOS, 1.48V in windows which droops to 1.46V under load. I haven't measured these directly off the board yet so is only just software readings.
This is nearly 9hrs orthos stable. plus i played an hour or two of farcry and css yesterday with no problems. Temps are reaching my personal limits at around 55 load, so i will test 520x7 tonight (3.64ghz) as my top 24/7 overclock, then will pump some voltage into the ram to reduce the timings from 4-4-4-8 hopefully down to at least 4-4-3-8, or at a push 3-4-4-8 :D
http://img135.imageshack.us/img135/5439/357ew2.jpg
Wow! I hit almost 10C more w/ the Ninja at those V.
http://i11.photobucket.com/albums/a1...MinionX/OC.jpg
Thats what I got
3200 MHz (v1.325)
Asus P5B Deluxe/WIFIAP rev 0711 - Arctic Cooling Freezer 7 Pro - Corsair XMS PC26400 (6400C4)
Ive had it Orthos and Everest stable for 24hrs+, ive been using it at these settings for about 3 weeks now not a single problem, multiple games played on it for 10hrs + (farcry, fear, halflife2, company of heroes)
Hows this lookin? I Idle around 35C and under 100% load with TAT Im getting like 48-51C on both cores.
Ive booted into 3.6ghz and ran a high 13s to low 14s SuperPI but it wasnt stable at all runnin a Vcore of about 1.4?
Brilliant OC :fact: :clap: :toast:Quote:
Originally Posted by adfinni
And the background looks even better :fact: :shocked:
Cheers !!!!!! Dropped the voltage a notch and ran orthos overnight, but it failed after 7 hours. Back i go into the BIOS for some playtime :DQuote:
The pic came from this thread :http://www.jacatu.de/wbb2/t7850-swed...ightclubs.html....................... A comparison of a nice swedish nightclub and probably the worst english nightclub in the country. Look at those swedish girls:eek2: :hump:
:shock: :eek2: :shock: :eek2: :party:
I wish mine can boot at 500 1:1. :(
Been testing each speed bump for at least an hour using LARGE FFT's, I'll post again once I get to 3.40GHz :)
http://i16.photobucket.com/albums/b29/alpha0ne/E633.jpg
Ic3man - 3753 @ 1.63v - Alphacool H20 - P5WDH - Corsair XMS2 c4 4-4-4-12
http://img.photobucket.com/albums/v6...0/3750crop.jpg
E6600
stock P5B 0614
air
Max 1M 9x 1.5625 vcore bios
http://img.photobucket.com/albums/v6...c/40601Mx9.jpg
Max 1M FSB 7x
http://img.photobucket.com/albums/v6...fsb5501M7x.jpg
Orthos 3600 1.4125 vcore bios
http://img.photobucket.com/albums/v6...rthos36001.jpg
what he said!!! wow.. those swedish chicks are hot candy. whew.Quote:
Notice that I stopped the Orthos before I took the pic - was getting under 60C too! - needed the cpu power for typing up that stuff moving stuff around and opening all the cpu-z screens.-:toast:Quote:
Originally Posted by Jodiuh
I´ve / We got a problem.
We isolated the area around the socket and placed a small portion of Artic Silver 5 on the CPU an adjusted the Cooler (modded Vapochill). He started it and nothing happen......my one thought, whats wrong....canted the cooler? a shorted-circuit....:confused:
No we´ve got some condensation under the CPU... The Board seems to be alive maybe.....it will be infuriating, if its dead, it could do 528-535 easily, ....or maybe the CPU ist dead...the RAM seems to be ok.
I hope you understand what i wanted to tell you.
