HDPC, Your FSB voltage looks low to me?
Here is my 1004 Bios settings.
Under Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Setting : 9
FSB Frequency : 424
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2-848MHz
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 50
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Enabled
Ai Clock Twister : Strong
Transaction Booster : Auto
CPU Voltage : 1.53750v
CPU PLL Voltage : Auto
North Bridge Voltage : 1.61v (BIOS) (Everest is reporting 1.65v's.)
DRAM Voltage : 1.96v (BIOS) (Everest is reporting 2.10v's.)
FSB Termination Voltage : 1.48v (BIOS) (Everest is reporting 1.55v's.)
South Bridge Voltage : 1.050v (BIOS) (Everest is reporting 1.09v's.)
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : DDR2_REF
DDR2 Channel B REF Voltage : DDR2_REF
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.50v (BIOS) (Everest is reporting 1.57v's.)
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
Under Advanced
And CPU Configuration:
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
Under Advanced
And USB Configuration :
USB Functions: Enabled
USB 2.0 Controller : Enabled
USB 2.0 Controller Mode: HiSpeed
BIOS EHCI Hand-off : Enabled
Port 64/60 Emulation : Disabled
Legacy USB Support : Enabled
