Originally Posted by
bhavv
Ok, this is the most 'efficient' I can get mine running:
I didnt test the gigaflops yet, just the stability. It will do 4 Ghz on stock voltage of just 1.21v, but just going up to 4.05 Ghz requires around 2.625v, so the perf / volts cuts off and becomes very inefficient over 4 Ghz on my chip.
The voltages might go slightly lower, but the ram is pushed to its absolute limit and wont be stable at less than 1.65v @ 1900 Mhz, just the CPU and QPI might work a bit lower.
I was only pushing it to the extreme when I first got it to test its capability, but this will be my 24/7 setting.
My GTX 560 tis run at 880 / 4600 at the minimum voltage of 0.950v, so everything is nice and cool for daily use, and then I go mad when running benchies :p
