http://i.imgur.com/Ri4DUgv.jpg
http://i.imgur.com/Z9hrzWv.jpg
http://i.imgur.com/UbPbep1.jpg
Are these crystal tubes bent or normal tubing bent ?
Good job. You really need to sleeve some GPU power cables though.
@h2oxide: Why the flow meter needs to be installed in a parallel setup against serial? Shouldn't it be measuring the flow in the loop?
Ah, I almost forgot to say, awesome build though...:up:
attachments are not shown...
sate200>
Is your Pump pushing liquid to the RES?
3 D5 strongs ????
Holy heck, are you pushing honey through that lot or what?
Oh well, I guess all overkill is good overkill :) Nice looking build man. I particularly like the white pump top. I haven't seen one before and it works really well.
http://www.overclock.net/content/type/61/id/1526276/
http://www.overclock.net/content/type/61/id/1526277/
http://www.overclock.net/content/type/61/id/1526278/
http://www.overclock.net/content/type/61/id/1526279/
I'm still missing two Gelid Silent Slim 120mm UV Reactive Fans and NZXT Sleeved LED Cable Kit - 2M - Blue
After lighting arrived and two fans
http://www.overclock.net/content/type/61/id/1547550/
http://www.youtube.com/watch?v=F1zRbuSlLBM
@Maxforces
First of all nice set up!
All Koolance if im not mistaken? I to want an all koolance rig (except rad)
What size fittings do you use is it 1/2ID - 3/4OD?
And what brand of tubing do you use?
Im wondering if those koolance compression fittings work great with primochill advanced LRT......
