Looks like the P45 Maximus II
Is this DDR3 with dual bios and the auto raid0?
Yeah it's DDR3 and has the auto raid. Don't know about dual bios as I can't see the chips in the photos.
Just look at the PWM cooling. #__#
what is the little joystick thing? can i play pong in bios?
You see, that is just stupid. Yeah woopi I don't need a keyboard in my bios. I just move this tiny joystick and hit these tiny buttons. . . .. -snap- OH NOEZ I broke it.
I couldn't agree with you more.
This was an adventure to say the least, but I was finally able to get a "sub-respectable" _stable_ oc.
Definitely not as easy as my IP35-Pro. The machine did 450x9 stable on air without batting an eye. It took a lot of time to get here on the MRF, but I have to say I am quite pleased with my new creation.
EDIT
Forgot to mention this was 8G.
Ai Overclock Tuner: [Manual]Quote:
Maximus "Rampage" Bios v0403 Settings
OC From CPU Level Up: [Auto]
CPU Ratio Control: [8]
FSB Frequency: [485]
FSB Strap to North Bridge: [333]
PCIE Frequency: [102]
DRAM Frequency: [971]
DRAM Command Rate: [2T]
DRAM Clock Skew Channel A:[Advance 300 ps]
DRAM Clock Skew Channel B:[Advance 300 ps]
DRAM Timing Control: [Manual]
CAS# Latency: [5]
RAS# to CAS Delay: [5]
RAS# Precharge: [5]
RAS# Active Time: [15]
RAS# To Ras# Delay: [3]
Row Refresh Cycle Time: [50]
Write Recovery Time: [6]
Read To Precharge Time: [3]
Read To Write Delay(S/D): [8]
Write To Read Delay(S): [3]
Write To Read Delay(D): [5]
Read To Read Delay(S): [4]
Read To Read Delay(D): [6]
Write To Write Delay(S): [4]
Write To Write Delay(D): [6]
?:[14]
?:[5]
?:[1]
?:[6]
?:[6]
DRAM Static Read Control: [Disabled]
Ai Clock Twister: [Stronger]
Transaction Booster: [Manual]
Common Performance Level: [9]
Pull-Ins-Disabled x 8
CPU Voltage: [1.47500v]
CPU PLL Voltage: [Auto]
North Bridge Voltage: [1.65v]
DRAM Voltage: [2.10v]
FSB Termination Voltage: [1.46v]
South Bridge Voltage: [1.100v]
SB 1.5:[1.5v]
Loadline Calibration: [Enabled]
CPU GTL Reference: [0.63x]
North Bridge GTL Reference: [0.67x]
DDR2 Channel A REF Voltage: [Auto]
DDR2 Channel B REF Voltage: [Auto]
DDR2 Controller REF Voltage: [DDR2_REF]
SB 1.5V Voltage: [Auto]
NB LED Selection: NB Volt
SB LED Selection: SB Volt
CPU LED Selection: CPU Volt
Voltimeter LED: Disabled
CPU Spread Spectrum: Disabled
SS:Quote:
http://www.chawks2.com/images/Puter/485x9.MRF.jpg
The new P45 board is just ridiculous. :shocked:
Dee Dee Dee! Have we not heard of bench testing and set up, Old school, the way we have always done it. Why waste all that time mounting, wiring everything and getting all comfy if you still end up having to remove it for another "dee dee dee" or a double check, or just for the ease of trying different CPU's and or cooling blocks. I've had boards benching and working for almost a month before fitting intop a case.
OK, I made these changes and the effects seemed to be minimal. As was mentioned by somebody else, I guess I can't change the Tref eh?
Damn :D
Anyways, since you said my pull-ins put me at PL4, I just turned them all off and put it at PL4. Passes memtest without issue. BUT, I adjust either the 1st pull-in for both channels to enabled, and she won't post, so it looks like I've found the limit.
Here's what the throughput looks like now:
http://www.darkfibrecommunications.c...memtimings.png
And the settings look MOSTLY like this, with the exception that PL is now 4 and we have NEUTRAL as the value for Read Delay Phase Adjust, and that seems to be all it will take.
http://www.darkfibrecommunications.c...strampage2.JPG
Im getting BSOD in games and ive run memtest and getting errors test 2 test 4 and test 7 on seperate runnings of the test.
Is my ram screwed? I posted on OCZ support forum but admin says that this might not mean ram is bad?
I had system @ 3ghz from december to about a month or two ago and then upped it to 3.3ghz a month ago and the BSOD have been happening in the last couple of weeks. I went back to 3ghz and BSOD still happening as well as errors in memtest.
Any ideas?
Hi,
I installed the the RAMs last night, but I am not having any luck OCing. I follow your template but getting OC failing (Det Ram). I noticed there are a few things different than yours.
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 400
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: DDR2- 1066
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# Activate Time : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
Write to PRE Delay: AUTO <---- I have these as well (start here)
READ to Pre Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO <---- end here
DRAM Static Read Control: AUTO
Ai Clock Twister : Stronger
Transaction Booster : Manual
C/P: A1 A2 | B1 B2 <---- Different than yours (Am I missing something?)
LVL: 04 05 | 04 05 <---- Different than yours (Am I missing something?)
Common Performance Level [7]
Pull-In of CHA PH1: Enabled <---- also different due to above setting
Pull-In of CHA PH2: Enabled
Pull-In of CHB PH1: Enabled
Pull-In of CHB PH2: Enabled
CPU Voltage : 1.4375 (or whatever you need for 3.6 stable)
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.49
DRAM Voltage : 1.92
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
Loadline Calibration : ENABLED
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED :
Advanced CPU Configuration
C1E Support : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Enabled
-hdpc
post your current bios setting?
try setting dram static, clock twister,and booster to AUTO, see if it boots then
if it does check your trd ( performance level) setting in everest
- Ratio CMOS Setting : 8
FSB Frequency : 450
DRAM Frequency: DDR2-1081
CAS# Latency : 5
RAS# Precharge : 5
Common Performance Level [8]
Pull-In's --> All Disabled
DRAM Voltage : 1.92
CPU GTL Reference : 67x
North Bridge GTL Reference : 67x
DDR2 Channel A REF Voltage : DDR2_REF
DDR2 Channel B REF Voltage : DDR2_REF
DDR2 Controller REF Voltage : DDR2_REF
Voltiminder LED :
USB Configuration
I've also set dram static, clock twister,and booster to AUTO but I still get Det Ram.
-hdpc
up your ram volts to 2.1?
Votage is rated for 2.0 - 2.1
