I test Noctua at extreme tdp and cfm (with deltas for now) and nothing can stay in his way, performs better than True Copper.
This is a sick setup! :shocked:
So that noctua heatsink with two Deltas and I dont know which fan is the one in the middle, performs better than a Copper or Megahalem?
And... that megahalem is a megashadow, isn't it?
Fan in the middle is delta 4000 rpm (not an advantage for NH-D14, in the middle do not fits 38mm fan). I test the delta 5500 rpm aginst the San Ace 6000 rpm and delta is a little better, under 1c.
I have nuch more tests to do (fanless, low rpm etc...), the point is that i test and retest the setups because i want to be sure about the results.
Noctua NH-D14 performs way better than Megashadow and Copper at extreme settings.
http://img193.imageshack.us/img193/5545/47785185.jpg
http://img42.imageshack.us/img42/7854/18114469.jpg
http://img690.imageshack.us/img690/5816/88480957.jpg
http://img690.imageshack.us/img690/1183/13023554.jpg
Got my Lian Li PC-A05NB friday, so made it into a small project.
- Sleeved the fans and lowered them to 5v.
- Sleeved the top IO-panel wires.
- Sleeved the power, restart and led wires.
- Sleeved the ATX4 extension.
- Routed the powercord extension.
- Scythe Himuros.
- P-clips for routing.
those temps seem a little higher than what they should be, or not? Mine maxed at 79ºc on the mega shadow (4608Mhz @ 1.494v load) with two scythe 110cfm'ers. Mine was on tech station too.
Regardless, sick setup man. Jealous you have the noctua and the mega shadow :(
I know its not prime 95, but prime 95 on my setup heats up less than anything else. Wprime runs hotter, and Linx/Intel Burn test work the best for me as far as max heat/power consumption.
http://img.techpowerup.org/091105/Capture175.jpg
I have the Aerocool Case, too ;)
But with another front ;)
Normal Front:
http://www.abload.de/img/dsc08835yqsf.jpg
Current:
http://www.abload.de/img/dsc08906xr38.jpg
My Plans:
http://www.abload.de/img/pc1lp5y.png
Beloe there is nothing there ;)
we wanna tests!!!
That Noctua cooler is a Moster, look at its size compared to the megahalems which itself is not exactly slender
My Previous post was deleted as I took new ones with a better camera :)
http://img694.imageshack.us/img694/4519/dsc00431z.jpghttp://img687.imageshack.us/img687/9917/dsc00429t.jpg
http://img36.imageshack.us/img36/1636/dsc00425zw.jpg
http://img36.imageshack.us/img36/3614/dsc00424if.jpghttp://img94.imageshack.us/img94/8577/dsc00416n.jpg
http://img237.imageshack.us/img237/5858/dsc00420i.jpg
http://img510.imageshack.us/img510/9971/dsc00417p.jpg
Yea, mine are all taken with camera phones too. I just remembered to charge up my K850i and use that instead of my LG.
Hopefully for my upgrade in July next year, I will be able to get a 12mp Phone with a full keypad, and proper flash, zoom, and focus.
The thing is that any more than 3.2 mp without a proper flash is major pointless, as I learnt with my LG Arena.
I cant be bothered with paying for a seperate camera since I get a subsidised high end Phone every 18 months :).
http://img163.imageshack.us/img163/357/51712838.jpg
http://img14.imageshack.us/img14/3900/52903380.jpg
http://img690.imageshack.us/img690/206/19907662.jpg
http://img14.imageshack.us/img14/2240/29338560.jpg
http://img14.imageshack.us/img14/7632/53568150.jpg
My Lian Li PC-A05NB, cooled by a TRUE Black and three stock Lian Li fans on 5v.
It's 5°C colder then my Antec 300, both in idle and load, and it's quiet too!
My Antec had all slots filled with Fractal Design fans on 12v.
The poor sleeving is stock on the PSU, the rest I've done myself with proper MDPC-X.
Not going to bother with sleeving the rest since it's just a temporary build.
Looks good Chickenit, quite colourfull too. :D
Though you need to do something about those wires on that testbench. ;)
Hi . My cam is K800i :D
Hi .Present it like this :
http://i632.photobucket.com/albums/u...C/DSC02736.jpg
And here is mine... :D
http://images.hardwareinfo.net/users...e/010037-5.jpg
http://images.hardwareinfo.net/users...e/010037-1.jpg
http://images.hardwareinfo.net/users...e/010037-3.jpg
Specs:
Asus P6T Deluxe | Intel Corei7 920 @ 4 GHz | Noctua NH-U12P SE1366 | 3GB OCZ PC12800 | Asus GTX 285 1GB | 2X Samsung Spinpoint F1 1TB | Nexus 850w | Lian-Li PC-60FW
Idle temp is like 29 C. :up:
Finally got my new case all ready :)
http://www.import-power.com/gallery/.../Light+OFF.png
http://www.import-power.com/gallery/...1/Light+ON.png
wow... nicely cut that p183 side panel. white light is so much kooler :)
with what did u cut that side panel so clean?
Thank you :) I actually ordered the panel from PugetSystems.com
I didn't want their logo on it, but don't sell it any other way. Luckily, it's not that big and actually not that bad looking. And yes, I'm very glad I went with white light.
VERY happy with this case so far (upgraded from Alienware P1)
