yep
yep
Damn, you guys are freaking lucky.
In order to get my E0 running at 4500 MHZ, it takes above 1.412 volts. At 4.25 any lower than 1.328 will cause problems. And I bought it in late December. The batch number is Q832A389
Any tips to lower the voltage would be appreciated, I want to keep temps down, especially in this warm weather we are getting over here.
Have you tried playing around with the MCH and CPU references? They have helped me run lower vcore before :)
9x500@4500 w/1.31v:D
i was able to lower my vcore by raising my vtt one notch for this run.
but theres only so much that can be done,the rest is up to the cpu.
http://i44.tinypic.com/11ca3kn.jpg
fatguy1992 was right about the mch refyou really have to find sweetspot
well i switched my mch ref from 0.750 bios/0.700 ET6 to 0.770 bios/0.720 ET6
and was able to drop my vcore even lower.
9x500@4500 w/1.29v
http://i44.tinypic.com/ohkz5s.jpg
http://i43.tinypic.com/r1jy4k.jpg
Just fiddling around with my parents PC. I didn't realize that their P5Q Pro was rev A3. :)
http://img196.imageshack.us/img196/5597/4050127500.png
radaja - what mobo?
Hes using a Gigabyte UD3R I think.
very impressive radaja
last week I had quite new batch Q830A931 of E8500 E0 and it was bad piece:(it was extra heating, because my Intel stock cooler is cooling my E5200 with 1.65V on 68°C Idle...but this E8500 on 1.28V had 90°C in BIOS and I didn't understand it...first step was with 1.4V, but after reboot was temperature in BIOS 125°C:eek:is it normal with stock cooler? my last E8400 C0 was cooling with this stock cooler on 1.5V and temperatures weren't over 90°C
E8500 E0 @ stock 1.024v
http://img188.imageshack.us/img188/1...0stock102v.jpg
E8500 E0 @ 4.009Ghz 1.24v
http://img188.imageshack.us/img188/4...009ghz124v.jpg
E8500 E0 @ 4.303Ghz 1.336v
http://img8.imageshack.us/img8/290/e...timestorun.jpg
E8500 E0 @ 4.503Ghz 1.416v
http://img41.imageshack.us/img41/1295/e850045ghz.jpg
Damn, I need to get me a E0
My E8500 C0 doesn't like anything over 4.3ghz on water
_AntLionBR_ our congratulations man! using noctua great result!
_AntLionBR_, me passa ( se possivel ) o setting que vc ta usando na bios ai para mim comparar com o meu o 4870@over me passou um mais ta muito mais muito instável e tirei mais agora quando tendo voltar ele não passa nem do carregamento do sistema!!!
Viva o Brasil!!!!!!!!!!!!!!!!!!
radaja, that's a great chip. have you tried max clocks on air for it? tried running SPi 1M at 5ghz? your chip looks very capable of that. and planning to ever sell it at a premium? :hrhr:
thanks guys,it is indeed the UD3R.i was without internet for two weeks
and it almost killed me:D
i havent tried going higher than 1.39v yet.but i will and see how high i can go on air:up:
and as to this "and planning to ever sell it at a premium?" you never know
with my job instability lately,it could very well be on the market at a moments notice
Still breaking in the CPU, got it this afternoon :).
Q845A837
3.6GHz (400x9) 1.12V
http://img15.imageshack.us/img15/7651/42346678.jpg
3.8GHz (423.3x9) 1.168V
http://img196.imageshack.us/img196/3761/44344387.jpg
4.0GHz (445x9) 1.248V
http://img188.imageshack.us/img188/183/75201886.jpg
4.0GHz (445x9) 1.248V using IBT
http://img200.imageshack.us/img200/5788/oc40ibt.jpg
Still in testing phase and yes I know I rushed through the lower speeds (will go back to them) but so far 4.0GHz@1.248V is running strong. Going to do more IBT runs.
I think I'm limited by my motherboard and my cooling... Heck its a CNPS9500! lol
Q845A837 bought it yesterday from Dell. :)
Stepping E0 worth every penny paid friend. It was not beyond 4.5Ghz. :D
Yeap. :D
Code:E8500 @ stock
FSB Frequency 333Mhz
CPU Ratio Setting 9.5x
PCIE 100Mhz
DRAM Frequency 800Mhz 5-5-5-15
DRAM Static Read Control Disabled
DRAM Read Training Disabled
MEM.OC Charger Enabled
CPU Voltage 1.04v BIOS real 1.02v
CPU PLL AUTO
FSB Termination Voltage AUTO
DRAM Voltage 1.9v 2T
NB Voltage 1.10v
PCIE 1.50v
LoadLine Calibration Enabled
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
C1E Support Disabled
CPU TM Function Disabled
CPU GTL Voltage Reference (0&2) & (1&3) AUTO
Espress Gate Disabled
Code:E8500 @ 4.009Ghz
FSB 422Mhz
CPU Ratio 9.5x
PCIE 100Mhz
DRAM Frequency 845Mhz 5-5-5-15
CPU Voltage 1.25625v BIOS real 1.24v
CPU PLL 1.52v
FSB Termination Voltage 1.26v
NB Voltage 1.12v
PCIE 1.50v
CPU GTL Voltage Reference (0&2) 0.65x & (1&3) 0.63x
Code:E8500 E0 @ 4.303Ghz
FSB Frequency 453Mhz
PCIE 100Mhz
DRAM Frequency 907Mhz 5-5-5-15
CPU Voltage 1.35000v BIOS real 1.336v
CPU PLL 1.54v
NB Voltage 1.16v
PCIE 1.50v
CPU Clock Skew 100ps
NB GTL Reference 0.615
Express Gate Disabled
Code:E8500 E0 @ 4.503Ghz
FSB Frequency 474Mhz
PCIE 100Mhz
DRAM Frequency 949Mhz 5-5-5-15
CPU Voltage 1.43125v BIOS real 1.416v
CPU PLL 1.54v
FSB Termination Voltage 1.28v
DRAM Voltage 2.02v 2T
NB Voltage 1.18v
PCIE 1.50v
CPU GTL Voltage Reference (0&2) & (1&3) 0.61x and 0.63x
thanks, _AntLionBR_! so get home I try and compare with my then post the result!
WhiteFireDragon,i decided to give it a go with Pi 32m and 1m
to see what the max OC on air i could get.
9x540@4860 ddr1296 pl8 1m Pi
http://i39.tinypic.com/29ks2l5.jpg
9x540@4860 ddr1296 pl8 32m Pi
http://i41.tinypic.com/2w65v8n.jpg
9x543@4887 ddr1302 pl8 1m Pi
http://i41.tinypic.com/11udqgx.jpg
9x543@4887 ddr1302 pl8 32m Pi.......my first sub 10 32m:D
http://i42.tinypic.com/ok0sgn.jpg
9x545@4905 ddr1308 pl8 1m Pi.......only 95MHz to go:D
http://i41.tinypic.com/302ns6g.jpg
9x549@4941 ddr1317 pl8 1m Pi
http://i40.tinypic.com/2qalaab.jpg
9x549@4941 ddr1317 pl8 32m Pi
http://i43.tinypic.com/eio49d.jpg
and finally im in the 5ghz club:D:D:D
9x556@5004 ddr1334 pl8
http://i42.tinypic.com/14aext.jpg
everest score
http://i40.tinypic.com/2zdytd1.jpg
Its a Korean girl group called SNSD (Girls Generation)
The original pic was all pink so I photoshopped it here:
http://img3.imageshack.us/img3/9125/...1680x1050a.jpg (1680x1050) :up:
Hi guys! This is my new toy (at air cooling):
http://www.pctunerup.com/up/results/...3814_E8400.jpg
:up:
nice Caml Light 4200MHz with 1.16v:D
that one should clock pretty high with decent volts
