Originally Posted by
Pntgrd
Well, I am a bit baffled by my system at the moment. I was running 4 sticks of Crucial Tracers with no problems for a few months. Then I had a stick die so I sent the set back for RMA. When I got the replacements, they were the single sided new ones. I don't know if they would have plyed well with my double sided as they were bad out of the box. I sent them back and got my replacement for the replacement yesterday, which are double sided. I installed them this AM and started off with a MemTest run, which passed with no errors. I booted into Vista and after a few minutes got a BSOD and reboot. I upped the MCH a bit and same thing. Relaxed the timings and same thing. I even tried running SPD settings with more MCH with the same results. SO I backed of the o/c but that didn't help either. I then tried Vista's memory tool but things passed with no errors there, also. I next pulled the new sticks out and reset all the voltages and o/c back to where they were. Things now were back to normal. I replaced the older sticks with the new ones and same result, works fine. Just to check if a slot had maybe gone bad I moved the sticks to the other slots. Things work just fine there. I now know it is not the sticks or the slots. What had happened that now keeps me from running 4 sticks of memory when it worked fine before? The only thing else that has been changed was I went to the 16.04 bios, up from the 14 during the RMA process. Could this be the cause?
