I, too, have gone total parallel with my build recently and seem to be getting a few tiny air bubbles trapped around the cpu inlet. Any tips on bleeding them out other than tapping the tubes?
Ive tought about all parallel before, but never seen anybody doing it. How are your temperatures? Can you give details on your loop?
http://imageshack.us/a/img89/8818/p1180369x.jpg
I understand that there are many questions about this solution.
I'm not a theorist, I want to try it in practice
and prepared to do so properly.
Someone had to finally take practice tests ... to find answers.
Work in progress, I decided to use a very strong pumps.
Koolance 450 Strong x2
Iwaki RD-30
Swiftech 35X turbo
After testing will present the results.
Prodigy from thai :D
http://image.ohozaa.com/i/5d0/yam1fg.jpg http://image.ohozaa.com/i/83d/hXsP9o.JPG
@Elder: looks like it's a very non-restrictive loop. Higher flow pumps should get the best results
That is gorgeous!
But, is that a kink in the hose going from CPU block to RAM block or am I seeing things?
Fractal Design Arc with 360 rad in the roof, 240 rad in the front, 120 rad i in bottom! Still some tweaking to be done but the major mods are done.
http://i.imgur.com/zaEoA.jpg
http://i.imgur.com/nDMw1.jpg
http://i.imgur.com/oc1jO.jpg
http://i.imgur.com/HdONS.jpg
Update again in Lian Li A20. With block cpu koolance 360 gold edition.
http://image.ohozaa.com/i/ac2/ts44oM.jpg
http://image.ohozaa.com/i/514/nYKoYn.jpg
http://image.ohozaa.com/i/f09/rBnqSB.jpg
http://image.ohozaa.com/i/g06/e7fSqx.jpg
Project 2nd Anniversary Lian Li Club in facebook
Check this out :)
http://www.darmacz.pl/index.php?main...roducts_id=407
Liquid cooled case gallery...not borderline gay national pride gallery...I bet you love the sleeved ones...
Here is my new build. A couple of teaser photos and an album linked below. Enjoy and PM with any questions. Sig is not whats inside. i5 , HD5850, two 240 rads, 8 gig ram, 1 TB HDD, and 120G SSD
http://i.imgur.com/B7kJIh.jpg
Bad Pic but trying to show the LEDs in low light since my other photos were outside
http://i.imgur.com/OHafch.jpg
http://i.imgur.com/Xx3Axh.jpg
http://imgur.com/a/0aNYn
Here is my new PC
Asus RIVE
3960X
16GIG Dom platinum
x2 GTX680
x2 Samsung 512GB 830 Series Raid0
http://i785.photobucket.com/albums/y...h_SDC10977.jpg
http://i785.photobucket.com/albums/y...h_SDC10975.jpg
http://i785.photobucket.com/albums/y...h_SDC10972.jpg
http://i785.photobucket.com/albums/y...h_SDC10971.jpg
http://i785.photobucket.com/albums/y...h_SDC10970.jpg
http://i785.photobucket.com/albums/y...h_SDC10969.jpg
http://i785.photobucket.com/albums/y...h_SDC10966.jpg
http://i785.photobucket.com/albums/y...h_SDC10965.jpg
http://i785.photobucket.com/albums/y...h_SDC10964.jpg
http://i785.photobucket.com/albums/y...h_SDC10962.jpg
http://i785.photobucket.com/albums/y...h_SDC10961.jpg
Latest build in my Silverstone TJ08-e with this parts EK Supremacy Cpu, EK 120 radiator, Magicool 180 radiator, Xspc Dualbay res with Alphacool D5, EK GTX 680 Acetal FC block
http://img836.imageshack.us/img836/8546/img1215ze.jpg
Uploaded with ImageShack.us
Will make a window soon for the sidecover !!
Nice build ante!
My build:
http://www.conman.se/4G/1.jpg
http://www.conman.se/4G/2.jpg
http://www.conman.se/4G/4.jpg
Edit new pic, now black mesh in top and front
http://www.conman.se/4G/5.jpg
Nxzt 810
Nzxt 1000w
Asus P8Z77-V Pro
Intel 2500k
2x8Gb Crucial 1600Mhz cl8
2x120Gb SSD Sata3
2x7970
Cooling:
EK 420 rad top
6 140mm pull/push
EK 240 rad front
2 Corsair SP 120mm push
EK cpu block
EK 7970 block + backplate
Alphacool VPP6 + Laing D5
Nice build you got there Conman :) What kind of reservoir are you using? I?ve been looking at that cage for a long time, it?s looks great but i?ll stick with m-atx right now.
Thanks :up:
http://www.aquatuning.se/product_inf...ol-VPP655.html
Alphacool res with one D5
Did a little work today, black mesh in top and front.
Pic in my previous post.
Gee... seeing all the incredible builds in this post makes my new build seem almost insignificant.
I just added water cooling... and made a build log in the build log section so I can keep track of everything I do.
But here is a quick taste of my 140.3 internal radiator build:
http://keithlm.smugmug.com/Other/Ove...7_270028-M.jpg
