Originally Posted by
CryptiK
Not sure about the high vs low BCLK thing, lower BCLK the system has less inherent latency than with higher BCLK's. Since these silly boards dont sit evenly on a given BCLK say I used 182 BCLK (~182.4 in reality) i'd be on ~4012MHz core, DDR3-1820MHz and 3640MHz uncore. Slightly higher CPU, 48 MHz less on the ram and 36 more on the uncore. I might get a little better performance. Thing is I hate uneven CPU/ram/uncore speeds and I try and make numbers that seem 'nice' and 'balanced'. That's part of the reason why its at 4005MHz. This CPU has no problem doing 4.5GHz @ 1.336v (see submission in 4.5GHz LinX club) but I dont need that much power, I probably wouldnt even notice. When I work it hard, renders/decoding/encoding/simulations etc, it takes so long anyway its a walk away come back in a few hours scenario and if it finished 15mins sooner I wouldnt be waiting for it so I see no need to push it and create more wear and tear on all the components. I also dont like running EIST etc so its full speed 24/7 and I'd rather not push it like that. With the 6 cores and 12GB ram it does everything I want it to at the current settings.
