Mmm funny part is I am South African ;)
Just here working in the uk.
Farmerbrown: love that build.. but the coils looks like you have candy canes in your rig!! lol
I use coils and I'm in the US. I've done multiple loops where the tubing was fine and then developed a kink down the line. The coils fix that. Then again I don't upgrade as quickly as most here, when I build something I expect to run it into the ground and when it's done I put linux on it and the box joins the horde so I'm probably more prone to this issue than most.
Some seriously amazing builds in here, well done!! Will get a few pics up of some of my watercooled machines when I can although they are not on the same level as most of these! :clap:
My new build:
http://sanbasestudio.com/temp/comp11.jpg
http://sanbasestudio.com/temp/comp7.jpg
http://sanbasestudio.com/temp/comp3.jpg
http://sanbasestudio.com/temp/comp8.jpg
Cooler Master HAF XM
Corsair HX850
ASUS SABERTOOTH Z77
I7 3770K
GTX 680
4 x G.SKILL F3-2400C10Q
SSD OCZ Vertex 3 120 GB
2 x 3TB + 3 x 2TB
EK-CoolStream RAD XT 360
EK-FC680 GTX + EK GeForce 680 GTX VGA Liquid Cooling RAM Backplate
Swiftech APOGEE HD
Swiftech MCP 350
XSPC Reservoir Laing DDC
3 x Scythe Gentle Typhoon 1850RPM
It seems that some have not read the rulesQuote:
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
Optionally, it would be nice if you could list your water cooling components.
I'll put my hat in the ring.
Attachment 130396
Attachment 130397
Attachment 130398
Attachment 130399
Caselabs M8 with extended top
EK Supreme Full Cu nickel plated CPU block
XSPC Razor 680 GTX full cover blocks with EVGA 680 GTX back plates
(2) Koolance PMP-400 pumps
(2) Koolance DDC pump tops
(2) Koolance DDC Heat sinks
(2) EK Multioption 150 Advanced Reservoir
Koolance HX-CU1020V 360mm Radiator
EK CoolStream XT 360mm Radiator
Phobya G-Changer 360mm Radiator
Aqua Computers Aquaero XT 5
(2) Aqua Computers PowerAdjust 2
Aqua Computers in-line temperature fitting
Aqua Computers flow meter
(20) Enzotech G1/4 (3/8" ID x 1/2 OD") compression fittings
(2) Koolance VL3 3/8" ID QDC fittings - New addition
Various BitsPower and Koolance fittings
15 Ft. Tygon Neoprene 3/8" ID tubing
(16) Xigmatek Orange blade/White LED 120mm fans
Attachment 130449
Attachment 130446
Attachment 130447
EVGA Classified SR-2 + 2x Intel Xeon X5680
Corsair Dominator GT 2000MHz CL7 6G x2
Caselabs Magnum STH10, 2x EVGA GTX680 Classified 4GB
1x Intel 520 480GB (OS), 3x OCZ Vertex 2 120G Raid0, 1x OCZ Vertex 3 120G
EVGA SuperNova NEX 1500
2x Bitspower Summit CPU blocks, 1 BlackFreezer SR-2 block, 2x DIMM6 Dominator blocks
1x Black IceŽ SR1 480,1x Black IceŽ SR1 360 plus 7x Scythe Gentle Typhoon 1850rpm
2x MCP 655 plus Bitspower Dual D5 Mod Top plus EK 250 Advance Res
2x EVGA GTX680 Hydro Copper Waterblocks with Backplate
1x Black IceŽ SR1 480, 4x Scythe Gentle Typhoon 1850rpm, MCP355, XSPC Res Top
Bitspower matte black compression fittings, Tygon Clear tubings
previous build using LittleDevil LD PC-V8...
Attachment 130448
A teaser of things to come...
http://i.minus.com/iyMyWCDz3cBHZ.jpg
Hello Guys,
my last watercooled HTPC build :)
video: http://www.youtube.com/watch?v=2XcMpd_Pp_k
Attachment 130829
Attachment 130830
Attachment 130831
Attachment 130832
Only the motherboard changed because the previous one was died, but I reorganized the water components.
PC CONFIG:
PSU: Corsair CMPSU-750AX Modular
MB: MSI Z77A-GD65 S115x
CPU: Intel Core i7-2600K 3.4GHz @4.1GHz
VGA: GIGABYTE ATI-AMD HD6970 GV-R697D5-2GD-B 2GB GDDR5 PCIE
RAM: Apacer 4096MB 2000MHz CL9 DDR3 ARES KIT
SSD: OCZ RevoDrive PCI-Express SSD 50GB
HDD: 2x Samsung 500Gb 3,5" HDD Raid0
SOUND: ASUS Xonar D2X PCIE
BLU-RAY DRIVE: Pioneer BDR-205
CASE: Thermaltake DH104 HTPC case
WATER-COOLING components:
PUMP: Laing D5 Solar
CPU: Koolance cpu-340 with socket 1155 mounting
VGA: EK Water Blocks EK-FC6970 full cover
HDD: Watercool Silentstar Dual Box
TUBING: Tygon 3603 19/13
RAD: Watercool MORA2 PRO
RESERVOIR: Koolance 120mm
FANs: 2x Scythe Gentle Typhoon 120 mm for CASE (blowing inwards on reduced RPM) and 1x Scythe S-FLEX SFF21D (800rpm/8.7dBA) for the PSU (reserve airflow blowing inwards).
Fittings: Monsoon Free Center Compression - Chrome, Bitspower Shining Silver Rotary 90°
system gross weight: about 30kg :D
....absolutely quiet of course. :)
Have a nice day!
Nice, what are your temps (and ambients) ?
Thanks! :)
The temps of this system highly depends on the environmental temperature and the RPMs of the 3 fan. I can set the RPMs manually with the knob on the back side.
In summer, when the outside temp was about 28 celsius than the load (gaming) temp was the following: CPU about 45-50 celsius GPU about 53-58 celsius. Without any tuning and the funs were on lowest RPM.
The minimal temps in idle mode and with 23 celsius outside temp are about 35-38 cesius by the CPU and GPU also (Funs on lowest RPM).
So, there is no problem with the temps at all. It is very good and stable system. :)
Sorry for my english.
Just built this on Saturday using some of MagisD's old stuff I bought. Sorry for the bad camera pics.
http://s6.postimage.org/63yavgdbh/20...2_06_02_09.jpg
http://s6.postimage.org/yuv4lij59/20...0_17_01_32.jpg
@ VIPER.... Will do when I get home from work. The top can hold a 240 rad BUT you have to use a thin one if you want fans on it. The case is a very nice case though. Very clean and very tidy. Sorry for the bad pic but i have a crappy camera.
Attachment 130867
Temps after 1 day IDLE work:
-ambient temp: 22 celsius
-fans on lowest RPM
Attachment 130949
Edit2:
Temps after 3 hours of Gaming (Medal of Honor Warfighter)
-fans on lowest RPM
Attachment 130961
I'm very satisfied again. :)
Let me know if you have questions.
Parallel.
Total parallel :D
http://img593.imageshack.us/img593/2556/p1180765j.jpg
http://img196.imageshack.us/img196/274/p1180776k.jpg
