This thread is full of inspiration!
I love it!
Black,blue,green,red..what colour to pick?
I love it!
Attachment 129927
Attachment 129928
Attachment 129929
Attachment 129930
ASUS Rampage Extreme
Core i7 3930K@4000
SLI ZOTAC GeForce GTX 680 4GB
32 GB Mushkin Blackline (8x4GB) DDR3 PC3-17000 10-11-10-28
2 x Corsair Force Series GT 240GB RAID0
Craetive Sound Blaster X-Fi Titanium Fatal1ty PCI-E
Seasonic X-1250 X-Series 80+ Gold 1250W
Lian Li PC-A71F
My small Cosmos - final revision.
http://www.abload.de/img/widok2j0uhw.jpg
http://www.abload.de/img/widok3c5udj.jpg
http://www.abload.de/img/noc0rd1y.jpg
http://www.abload.de/img/obudowa0d4u2e.jpg
http://www.abload.de/thumb/obudowa1yduel.jpg http://www.abload.de/thumb/obudowa2btu5p.jpg http://www.abload.de/thumb/obudowa38uujj.jpg
Fantastic job. Hard to find a single flaw or shortcut in the any of those pics. You should be proud. :up:
Thanks, I'm proud and happy :D
^^^^^^^Cleanest build I have ever seen, absolutely beautiful^^^^^^^^^^^^^
just saw the rest of your other pics.. :up: looks greattttt!
Leak test underway....
http://i.imgur.com/qSKD1.jpg
http://i.imgur.com/klJY2.jpg
What kind of tubing is that B negative!?
it's a coolermaster stacker 830 nvidia edition.Quote:
looks like my case but fulll-atx, where can I find some pics? wich case is that?
@B Negative: Builds with copper pipes aways makes me think: How to disassembly it? How do you do it? Can you keep on using the sabe pipe for various mounts? Also, since your tubing is chrome plated, is galvanic corrosion a problem?
@LeoAndrade: Itīs easy if you use rotary fittings for angled connetions ;). For parallel connectors your only have to bend the tubes to the right distance and plug them in - disconnection is the same way.
Corrosion is not any problem since chromium is a nearly perfect corrosion protection. Though the inner surface is pure copper - the tubes are only plated on the outer surface.
Just Finished Rev 2
Let me know what you think :)
http://i1270.photobucket.com/albums/...ps5dc49017.jpg
http://i1270.photobucket.com/albums/...psb105b90a.jpg
http://i1270.photobucket.com/albums/...ps1e252e97.jpg
http://i1270.photobucket.com/albums/...ps1436272a.jpg
Just Finished Rev 2
has anyone ever noticed how much using coils is a british thing?
like i dont think ive ever seen someone use coils, and then not find out they're a british builder.
Just release the lock ring and remove the pipe..easy.
You will need to make a new pipe every time you change a component to a differing model.
Its only chromed on the outside,the actual bore is copper. Chrome is also far better than nickel for corrosion resistance.
^ Clean build very nice case.
