question... is there a pencil mod for this board or do i have to soldier resistors in?
I think your gonna have to do some soldering. This thread talks about all the volt mods for this board
http://www.xtremesystems.org/forums/...d.php?t=152233
Just wanted to give my thanks for many of the posts on this thread. Made a huge impact on my decision to go with this board, and everything has been running smooth!
no beta update this week as long as CeBit is going on...i was told by Bingo13 that the bios engineers go to CeBIT to answer those pesky performance questions on the newest chipsets:D
Well, there is such a thing as an optical splitter. It looks like this : http://www.cablestogo.com/product.as...=102&sku=27027. But 2 rooms worth of toslink cable might get a bit expensive.
compared to my previous post and after doing the WinXP Tweaks...
am I finally doing this right::confused:
http://img507.imageshack.us/img507/9369/3408pi0.th.jpg
I dunno...this is kinda scary now...any advice or hints what I should do...first time I OC a cpu
http://img530.imageshack.us/img530/2086/3408pb3.th.jpg
Well, I finally got my board to work with all Four 2GB sticks! It would work fine with either pair for a total of 4GB memory, but wouldn't even boot with them all installed. I had tried just raising voltages and relaxing timing, but no dice. Then after a suggestion on looking at timings in MemSet and further tweaking I finally got it working. I tightened many of the memory timings, and relaxed tFRC. The timings I currently have (from MemSet) are as follows, which can be compared to the earlier timings (which were the "AUTO" settings in BIOS) which are also listed. I intentionally tightened the first few timings to the specified timings for my memory, and intentionally lengthened tRFC since a poster suggested that it might be one of the ones to play with.
I also raised MCH to 1.33 volts and ICH to 1.09 volts. (I had previously tried just the voltage increases and they alone were not enough to get all the sticks to work, so I suspect it was the timing changes.) Timings were set in BIOS and read out via MemSet.
Of course, Vista wasn't happy and insisted that it be reactivated, which necessitated a phone call to Microsoft. The "nice" lady there seemed to want to imply ("how many pc's is your software running on?") that I wan't legal, but gave me the new key that I needed.
Readings from MemSet: the 1st timing listed is what is now working. 2nd timing listed is what didn't work with 8GB, but worked fine with just 2 sticks.
Cas# Latency (tCL) NOW @ 5 old timings which wouldn't work 6
Ras# to Cas# Read Delay (tRTC) 5 6
Ras# to Cas# Write Delay (tRTC) 5 6
Ras# Precharge (tRP) 5 6
Precharge Delay (tRas) 14 15
All Precharge to Activate 6 7
Refresh Cycle Time (tRFC) 50 (0nly one raised) 46
Performance Level / Read Delay (tRD) 8 9
Write to Precharge Delay 14 15
Write to Read Delay (tWTR) 11 12
Activate to Activate delay (tRRD) 3 3
Read to Write delay (tRD_WR) 8 8
Read to Precharge delay (tRTP) 3 3
All Precharge to Refresh delay 6 7
Refresh Period (tREF) 2600T 2600T
Command Rate (CR) 2T 2T
I think I'm going to settle with 498x8 as that seems to be providing me with the best performance/stability island - details in the pic:
http://i271.photobucket.com/albums/j...stemStats3.jpg
GOOD SHOW!...you were persistent and it paid off big time!:up:
as to having to get a new key from M$, they have a scoring system which is part of your install...the scoring system is tallied and stored as a digital signature...from there on, it keeps tabs on changes to your system hardware...if you change the original point tally by 3 points (total points are 10), then you need to get a new key...thing to keep in mind, the network card is worth 3 points where as hard drive and memory is worth one point...what i am not sure; adding and subtracting multiple hard drives and multiple memory sticks count as only one point, two points or more....probably, your swapping out memory sticks set the M$ monitoring bell off (big brother keeping track) forcing you to call in.:yepp: most likely
this is how M$ keeps track of mobo changes...possibly, as their thinking goes, you are trying to install the OS on a secondary computer, which is not allowed.:)...that is what they are trying to prevent.
I thought I set the Core Voltage at 1.3 in the BIOS but, it seems to be read by CPUZ @ 1.28, don't know if that's the same one we're discussing.
Remember, I never OC any PC before so this Abit IP35 is taking my virginity away:rofl:
BTW, where can I get these 40mm fan? and how do I secure them on the board once I install the board inside the case?
As, always thanks to everyone for sharing their settings and experience.
I'm learning so much.:up:
Thanks for the input. The s/pdif splitter is closer to what I am after. The problem I have with that is that the sound will be the same on both speaker sets. I would like the ability to have media center running in the living room on it's own sound, and me playing a game on the other 5.1 system (from one computer still).
The optical and analog ports will both produce sound from the motherboard audio. Since my living room setup has taken the only s/pdif output from the onboard sound, I am left with the 7.1 analog still. Is there not an adapter of some sort (can't find for the life of me) that will take the analog output from the htpc and convert it to coax or optical digital for me??? Looking forward to some more feedback here!
Toslink cost not an issue with ebay. I have 50 foot dvi's hdmi's and toslink now added to the mix for cheap cheap cheap on ebay!
JJ
I lowered the Core Voltage to 1.25 I believe...see if you can make a recommendation:
http://img254.imageshack.us/img254/9887/3408vc5.th.jpg
advance thanks
with the E8400, it is about the same as my QX9650...to get a 1000 mhz over stock, i've seen about 1.28-1.30v actual vcore...remember, this is not locked into concrete since every cpu is different when it comes to overclocking...
this below overclock (your image) is using to much vcore, in my opinion...try lower vcore for 3.4 mhz
http://img530.imageshack.us/my.php?image=3408pb3.jpg
yeah I think that's when I was using the uGuru to "play with"...but now I'm doing everything in the BIOS....I'll go back to 1.30v again, let it run for 8hrs and see anything would pop up.
Then I'll probably bring up the Bus Speed...just don't know what's the next number I need to enter...what's next to 334.0 MHz?
Is there a website that tells the next scale number?
That part I didn't find a link to how to scale....
I'm just trying out one parameter at a time.:)
Advance thanks...
Found this on [H]ardforum:
maybe I'll got 400MHz...if that 333MHzX9 runs stable for even 4hrs.Quote:
Originally Posted by firas
stay 1:1 FSB to memory while you adjust the other parameters.
MCH, ICHIO and Vdimm play roles in attaining max overclock besides vcore.
try MCH of 1.4x; ICHIO of 1.65 and Vdimm of 2.1 to 2.2 to attain 3.6 mhz using 9 x 400 FSB (CPU VTT set to 1.3)....you can adjust up or down from there to see if it helps or hinders.
use Uguru to adjust your voltages...cpuz vcore is fairly accurate for vcore readout...don't forget that cpuz conflicts with uguru when both are visible on the desktop...just minimize Uguru when you want to open cpuz.
once you got your final overclock then adjust your FSB to memory ratio to see how high you can get your memory...don't forget max memory speed means more stress so voltage increases might be necessary to hold it stable.
good luck!:)
http://img264.imageshack.us/img264/4...c3d8ds9.th.jpg
can't wait to go home:up:
just changed my hsf to TRUE from zalman 9500..... my cpu temp went down but my pwm went up... think my 9500 was blowing on to the hs for the pwm... what size fan should i get to mount on to my pwm and how? with zip ties?
