Originally Posted by markodude
Hi guys, just to let you know I have put together a 2.13 and P4P-800VM with the CT-479, will report back how I get on with overclocking it - a bit frustrated with the lack of FSB adjustment in bios but sure I can get around it somehow :)
First thought was to wire mod the ct-479 to default 800fsb but I have not looked at the specifics, (I know these ASUS boards seem to hit ocing walls if the default FSB is not set to 800). Anyway its just installing windows so I will look at that later.
Thanks for all the useful info :)
EDIT - Now at 166FSBx16 = 2.6ghz RAM is only stable at 3-3-3-8 using 3:4, max FSB I have had is 185, now I seem to be hitting a wall around 170-180 as usual with the ASUS boards...oh and I see bigtoe suggested the 800fsb mod already, hoping as I have muti adjustment in BIOS I should be able to boot at 800FSB, just need to find the pins - can anyone advise?
