a DFI NFII Infinity doesnt need a Vdimm mod right? It already has 3.3v in the bios?
Children, children...settle down, or I'll get the rod.
Regardless of what 12x200 scores you can get at 2-2-2-8 or 2-2-2-11... the fact remains that I cannot run stabily at 2.4Ghz without pushing some serious juice 2.0V to CPU core... and then just barely.
yes, that's correct. :)Quote:
don't spank me. :DQuote:
what cooling are you applying on the CPU?
some bartons are tough to overclock, just like there are always the dud ones. One of the bartons I had needed 2.0v to barely run 2.3ghz stable air cooled.
hows this?
this is about the best I can do with this Corsair XMS 3200.
it doesn't seem to like the voltages too much.
I don't get much of anything from 3.5 volts to 3.9 :(
just 6 measly MHZ...
oh well, better then nothing huh?
always got to get every last Mhz, even if only to break a goal.
when I got 3800, 3900 was my goal-then eventually 4000 if possible, but it doesn't look possible with this ram.
maybe a different BIOS would help...
APIC off, Clean Intall of XP Pro, 3.9 volts on ram, cas 2-2-2-11@266 mhz for 2.53 ghz all done with air cooling :D
Hey, nice OC Kunaak :) :thumbsup:
But did you notice turning off APIC resulting in much lower bw efficiency? 92/85% is bad ;)
Could be better... :D Maybe you could break 4000 this way ;)
Good luck.
Edit:
And using win2kpro will yield you better bw too :D
I was benchmarking for 2 days with Apic on, before I turned it off and did a repair install of the OS, with Apic Off, there was no difference.
Xp boots at speeds 2000 just doesn't handle, so I choose Xp for these shots.
http://mitglied.lycos.de/rookiekille...2K/protalo.JPG
i have 4gb/s @ 260 fsb 2-2-2-11-10-12 :banana:
kingston khx3200 @ 3.3 volt
I get 4000 at 254 fsb.. that's what i call "high torque".
what mobo? =o)
That's really strange :confused:Quote:
I so often hosed up my winXP that I switched over to win2k... never regretted it :)
Edit: I think it's more bad if you do not re-install win with apic on... perf-wise, I mean. Clean install is holy... ;)
DFI Lanparty b. :)Quote:
Originally posted by rookiekiller
what mobo? =o)
ASUS A7N8X DLX 2.0 (Über 1007)
10*257MHz (Barton @ Duron), Air cooled -6.5 dec.
2*256MB KHXPC3000, 11-2-2-2
3984/3727MB/S
Here's my Infinity, AXP 1700+ and Twinmos BH-5 result :
http://www.geocities.com/henry_moniaga/dfi_261fsb.txt
http://home.kabelfoon.nl/~vnrswk/4191MBS.jpg
DFI Infinity
2400+ Mobile
Vdimm: 3.59v
VDD:1.9v
Vcore:1.85v
4K :D and mobo @ R.I.P ;)
http://www.saunalahti.fi/~chedu/team...dra4krikki.gif
4.1K Finally :D :D
http://www.geocities.com/henry_moniaga/dfi265fix.txt
If u use 9,5 or 10,5 you will get 4K float easy.. 10 is a bit slower. I went over 4K float @ 270MHz x 10,5.Quote:
Originally posted by RAMMIE
DFI Infininity
Mobile Barton 2400
2x256 Buffalo PC3700
Hello Overclocker friends.
Is this the very well known DFI "supermobo"?
http://www.databutikken.com/dk/datas...Id=DFILANNF2UB
Sry, but is in danish..
http://upl.silentwhisper.net/uplfold...zsisoft1gb.jpg
:toast: 1Gb powa... Not maxed ;) need beter out temp ;)
congrats... :slobber:
With 2x 256MB HyperX PC3200 BH-5 & stock DFI Infinity
http://mitglied.lycos.de/freshmeat666/Sandra261.jpg
Is this thread no longer a sticky?
http://www.zone.ee/tomz/data/rekordi...ndra_2k4.jpg?2
corsair bh-5 @3.2v
Hell yeah my thread still lives!!!! RAWR!
can I see a sandra2004 screen just like mine ? ;) with all the numbersQuote:
Originally posted by IamAnoobieCheez
damn.
DFI does have more bandwidth clock for clock, indeed...
... No Wpcredit tweaks no nothing..
using a little tbred chip.
Lanparty b @ 200fsb
oh and increasing fsb (i need 2 mhz to get the same score as you:D) , sandra benching then lowering fsb opening cpu-z doesn´t count ;)
i only changed 2 offsets that change two timings , some that are on the dfi bios
if you can do that score lots of guys can do it because you dont need wpcredit for it , just bios ill test it tomorow at a friends with the same dfi bios
