Latest November beta BIOS from DFI website seems to read correctly with Opti 170...Quote:
Originally Posted by Perc
-pickles
-pickles
After following this thread I decided to get an Opteron 170. Ordered my cpu a week ago from newegg hoping I'd get a good CPU. Anyhow my cpu arrived last tuesday and was happy to find a CCBWE 0530TPMW in the window :banana:.
Here is a shot at 2.8ghz with only 1.375 volts stable :woot: .
http://img511.imageshack.us/img511/5602/prime8qm.th.jpg
WOW daender VERY nice! Try more volts?
Has anyone killed one of these things with volts? Every chip I get LOVES voltage and this looks to be no exception but it's for my daily rig and I can't afford to replace it so I haven't gone over 1.6v after remembering someone kill a DC opty at 1.75v or something?
Very nice.. takes me 1.4 for 2.8 GHz...Quote:
Originally Posted by daender
Let me know if you are able to hit 3 GHz with watercooling.
guys what do you make of this TCaseMax reading.........49C....can't be right
AMD64 TCaseMax - v1.13
CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 3, Stepping: 2
Extended CPUID: Family: F, Model: 23, Stepping: 2
CPUID String: 20F32
Processor APIC: 0
Processor: Dual Core AMD Opteron 165 (Toledo)
CPU Speed: 2799.27 (311.03 x 9.0)
Revision: JH9-E6
Platform: Socket 939
Startup VCore: 1.350v
Maximum Case Temperature = 49C
TDP: 35.0 Watts
Written by: Arthur Liberman.
Idea by: Petr Koc.
More info at: http://www.thecoolest.zerobrains.com...topic.php?t=83
Why can't 49 be right? There are plenty of dual optys with a 49 tcase.
Here's mine:
CPUID String: 20F32
Processor APIC: 0
Processor: Dual Core AMD Opteron 170 (Toledo)
CPU Speed: 2800.79 (280.08 x 10.0)
Revision: JH9-E6
Maximum Case Temperature = 51C
TDP: 45.0 Watts
Idea by: Petr Koc.
it's just that i've seen single core ones 50C and above so seemed a bit lowQuote:
Originally Posted by fareastgq
what is your offset....mine's -1C
my 180 optie is 49c in that maxcast program. i thought it was a bit low when i seen it but it has no effect on the over clock so i havent worried about it since...
http://www.ausfx.com/gallery/albums/...80%20optie.JPG
guys ive tried bios 704 2bt 704 2bta and the new 11/14 relese and all three reconise my optie 180 as a optie 280? this is wierd anyone else have this problem? thx
daender
yup you got a good stepping same one as mine and i can dual prime at 2760mhz using the chips defualt v-core of 1.31v (atleast thats what cpu-z shows its set to auto in the bios) and so far im stable dual prime at 3gigs 1.45v and climbing... hope yours shows the same potentail as you raise the v-core...
peace perc,
would an opteron 170 with the steping CCBWE 0534SPMW be worth it, or should i test my luck and buy one from mwave or newegg?
subzero, why are you using 8x multi, you are forcing yourself to use a higher fsb than necessary. 9x300 will give you 2.7ghz. also, ldt multiplier is not the same thing as the cpu multiplier. the cpu multiplier determines cpu speed, ie 9x300=2700. the ldt multiplier determines the speed of the hypertransport bus, which is rated for 1000mhz. going over 1000mhz will most likely cause instability. some people get away with going a little over (my dfi can do 260x4) but if you are having problems then you should lower the multiplier to eliminate hypertransport as a possible cause. ie, if you are doing 300x9, then then use 300x3 for ldt.
-7c :)Quote:
Originally Posted by dinos22
is anyone running their dual core in the new DFI Expert board........mine is showing seriously low temps.......
Priming at stock 25C load temps .......idle 20C........don't forget i live in sydney......hence not exactly cold if you know what i mean this time of year
http://img499.imageshack.us/img499/6...ours2ba.th.jpg
here is the idle temp
http://img243.imageshack.us/img243/391/idle2ty.th.jpg
here it is priming at 2.6GHz 1.42V.....32C load ......can't be that low can it
http://img511.imageshack.us/img511/1...v33m7qj.th.jpg
Will be in a week, but still a lot of time to wait :cool:Quote:
your 170 survived that fire or what hehehe....let us know how you goQuote:
Originally Posted by mrlobber
hey here is a shot of my mem effinciency using my ballistix pc4000 2gig kit. im not over clocked but 230htt still it shows a nice 89% eff the other day i had it as high as 91% posted this just for you :) ...Quote:
btw: will have this cpu in the DFI expert series wedsday...
peace perc,
excellent, thanks bud, I always look at that instead of the bandwidth itself. I have 3 cpus and that an32 just isn't getting here fast enuff.........Also, Dinos, the CF board I had, it showed temps really low too, I think the probe is off by at least 10c. Might wanna give it that buffer, don't wanna end up with a fried chip. Guess u could always stick a prob on the IHS or core.
I've got my Opty 175 stable @ 2.6GHz now. Running 5/6 memory divider and (gulp) 1.55V. Max. temp thus far has been 50 degrees C, but that was a worst-case-scenario 2x Prime 95 small FFT torture test. She's been running @ 2.6GHz for over 24 hours now with nary a hiccup, and running 2x F@H WUs the entire time. 2x SPI 32M stable as well.
http://img.photobucket.com/albums/v2...an/2point6.jpg
i would like to know this too...Quote:
Originally Posted by pzerofgh
i say you probly still stand a good chance at a early steppin. i wouldnt wait too much longer these optie are sellin like mad! dont think early steppin be around much longer...
peace perc,
I'm thinking about buying a 175 in a couple of weeks.... or maybe a 180... What the good stepping for the 180? I will have the funds for it, so I was thinking that I would likely achieve a higher OC with the 180, but is that the case? Is it worth the extra $? I've skimmed this thread and didn't see too much on the 180... Perc, how is yours treating you?
mines ok but i wouldnt buy it again infact i may buy a 170 and try that if i can get the same over clocks id probly sell the 180 to recoupe a little cash. kinda sucks having 650-700 into a cpu when a 400 dollar cpu would bring me the same clocks...
peace perc,
Yeah I did that when the X2's were released. Bought a 4800+ and then got smacked around by everyone with a 4400+. Now my 170's are smoking the 4800+ as well..........
wow - ok - this is good to know. Guess you end up paying about 3 bills more for a better multiplier then. hrm... I'm going to keep reading up on the 170 and 175 before I buy anything... Thx for the heads up!
I have Opteron 170
CCBWE 0530TPMW
It does 2.8ghz with 1.5v, prime stable
Super pi capable upto 2.95ghz
Wont boot over 3ghz
Huge problem on dfi nf4 ultra with pwm temps, without active cooling the board probably would fry. I have seen it reaching 80c and freeze. Anyways I done with dfi I and I will be getting new asus board once it becomes available.
