Any cpu EXCEPT a quad-core :p:Quote:
Owkey, I installed a few server03 OS'es with my 3000+ venice at:Quote:
Originally Posted by dinos22
7x200=1400
8x200=1600
9x200=1800
9x333=3000
Same timings, mem speed ... Only the multiplier changed the first three installations. The last one was done with 133 divider.
The 3000 > 1800 > 1600 > 1400 installation when benching at the same speeds.
Are you speaking of installation times or actual speed of the benchmarks when you refer to one being faster than the other? Got any screenshots for bench results?Quote:
Originally Posted by massman
BTW-- my comment about installing the OS overclocked was joking ,that is definitely not one of my tweaks lol :D
In fact the last time I installed 2k3 I did it at 800mhz more than previous time because I was too lazy to go back into bios to lower settings, and the times were indentical on all of my pre-ln2 run checks.
Actual speed of benchmarks. Results were on the crashed OCX forum and I haven't saved the screens.Quote:
Originally Posted by k|ngp|n
S7 there are two things not helping you thereQuote:
Originally Posted by s7e9h3n
the chip is B1 stepping
you are on 680i mobo
move to P965/975 and find a B2 chip and you will start hitting low 13M :toast:
i just find this comicalQuote:
can you tell us what the difference in times was between 1M and 32M at same CPU speeds after every one of those installs
Managed to shave off more than 30MHz for sub 13minutes:
http://img.photobucket.com/albums/v6...2min573755.jpg
Still miles away from KP though.
Probably the fastest for i975X yet though.
Zeus have you tried 3-3-3-x timings on 975X.....you should be able to do better with tighter timings from what i've seen on all W.R. attempts with 975X ...none of them ran CAS4
Hm, getting the CAS 3 power to do it would be difficult. I should have tried when I had the chance. My guess is 460x8-470x8 3-3-3 with the right subs would pull it. But yes, 450 3-3-3 is about 5-10 seconds faster than 500 4-4-3 on i975x, though it takes a hell of a lot more voltage, and much better clocking silicon for both the ram and northbridge.
I did 13:21 myself at 450x8, never posted it out of shame against these super 965 times. :D
I was really intrigued by this so decided to give it a little test for myself and here is what I found:-Quote:
Installed at 9 x 266 (2.4GHz) - Bench run at 9 x 400 (3.6GHz)
http://i135.photobucket.com/albums/q...ultinstall.png
Then I installed @ 9 x 500 (4.5GHz) - Bench run at 9 x 400 (3.6GHz)
http://i135.photobucket.com/albums/q148/JAFFA22/4.png
I figured that the vast difference in clocks at install should show any inconsistency if there was any, but basically they turned out pretty much identical, Slightly interesting that the second run started out marginally quicker then slowed down until in the end it was a couple of seconds slower, but nothing to get excited about.
Oh well was worth a try, nothing ventured nothing gained as they say :toast: :D
Maff
nice one Herms (Maff) :D :lol2:
so much for that theory heh
Farrrk me Maff I dont think I have ever seen anyone load an OS @ 9x500 :shocked: :party: :cheer:
I tried but something on my rig has a big dislike for CAS 3, don't know wheter it's the board or the RAM, tried to boot at 350 with 2.4V but it doesn't make it all the way into windows.Quote:
Somewhere in the end when it's loading the USB driver for my wireless dongle it's hanging.
I think the mem should be capable of doing CAS 3 somewhere up to 400MHz at least (Gskill 6400HZ) with reasonable voltage.
Also tried 2:3 divider but that's a sort of same story as CAS 3, the board probably hates it.
I will try some more but i don't want to fubar my OS as it's my everyday install. :D
I tried 4-3-3-7 with my HZ's in sig and no matter the Vdimm or sub timings they just wont play stable, thats using both 975 and 965 boards :confused:
Heh, heh, heh........We are all of theories and nothing else as for gain....
My theory is to install Windows at 166MHz fsb with the lower multi x 6 ......Thas will give you EXACLTY 6.780sec less in 32M......;) :rolleyes:
LOL, try installing XP with this then :DQuote:
Originally Posted by hipro5
From here --> http://www.winhistory.de/more/386/xpmini_eng.htm
Dumn!......I bet that you'll get the BEST time even.....:DQuote:
Originally Posted by SLi_dog
My first result with new mem kit. Stil a lot of work to be done :D Need a little more vdimm for 600 4-4-4.
570 4-4-4:
http://img.photobucket.com/albums/v2...2M57144410.jpg
I wish I'd remember, but I tested it a long time ago. If you want ... I can't give it another try this weekend ;)Quote:
Windows XP?Quote:
Originally Posted by HermS
yes massman.
I used Server03 to do the tests + A64.Quote:
I just checked my other hdd, but haven't found the screens :(. If there is serious interest, I'll do the tests again this weekend. If you all think this is worth nothing, please tell me, so I won't waste time.
Finally making some progress....Check out the Vmem ;)Quote:
http://img76.imageshack.us/img76/769...332m2k3wx9.jpg
Very nice memclocks and timings but the calculationtime is still bad.
Congrats on breaking 14 minutes, must have been a relief. :D
