yea i have mine set at 1.425Volts and CPU-Z says i am using 1.456Volts.
idk why, but it isn't causing problems
X2 4800+ Brisbane @ 3.0GHz:
http://valid.x86-secret.com/show_oc.php?id=381324
Using Gigabyte GA-M57SLI-S4 mobo, 1.4V, although I have an overvolting Gigabyte board like several others here. During OCCT stress testing the voltage peaks at 1.49V.
X2 3800+ Toledo * 3,20 GHz @ 1,500 V * LCBQE 0718 VPMW * Wakü @ 25°C * ohne HS * 3,2 h DualPrime * Techtrancer * Link
http://www.abload.de/thumb/x2380032021525b44.jpg
AMD X2 3800+ Toledo * 3,00 GHz @ 1,440 V * LCB9E 0719 RPMW * Wakü @ 24°C * ohne HS * 3 h DualPrime * Techtrancer * Link
http://www.abload.de/thumb/30001475v3stundenpriyja.jpg
AMD X2 3800+ Toledo * 2,90 GHz @ 1,520 V * LCBIE 0621 VPMW * Wakü @ 29°C * ohne HS * 3,5 h DualPrime * Techtrancer * Link
http://www.abload.de/thumb/29901550jsc.jpg
AMD X2 3800+ Toledo * 2,97 GHz @ 1,520 V * LCBWE 0617 FPMW * Wakü @ 24°C * mit HS * 3,2 h DualPrime * Techtrancer * Link
http://www.abload.de/thumb/29901550j6j.jpg
AMD X2 4200+ Toledo * 3,15 GHz @ 1,504 V * LCBQE 0723 VPMW * Wakü @ 24°C * ohne HS * 3,1 h DualPrime * Techtrancer * Link
http://www.abload.de/thumb/31501525g8u.bmp
AMD X2 4200+ Toledo * 3,00 GHz @ 1,456 V * LCBQE 0723 VPMW * Wakü @ 34°C * ohne HS * 5,0 h DualPrime * Techtrancer * Link
http://www.abload.de/thumb/3000mhz1475ebayfertimi1.jpg
X2 4200+ * 3.41 Ghz @ 1.472V * G2 CAABG 0805BAA * WaKü @ 42°C * ohne HS * 2,5h DualPrime * Techtrancer Link
http://www.abload.de/thumb/x24200g2caabg0905baa0dp.jpg
X2 4200+ * 2.45 Ghz @ 0,992V * G2 CAABG 0805BAA * WaKü @ 30°C * ohne HS * 2 h DualPrime * Techtrancer Link
http://www.abload.de/thumb/245310vfertiguii.jpg
http://valid.x86-secret.com/show_oc.php?id=383084
Nothing much to say against that. Despite i have the Zalman 9500 CPU Cooler, heat goes up massivly when this thing is chrunching @ 100%, resulting in errors and failures. This is kinda the max limitation of the cpu.
X2 6400+ * 3,62 Ghz @ 1,568V * F3 Winsor * CCB8F 0809 BPMW * Watercooling @ 44°C * mit HS * 2,2 h Prime * Techtrancer Link
http://www.abload.de/thumb/36201568vfertig1kb.jpg
new motherboard, new score :)
AMD A64 X2 4000+ @3517Mhz 1.68v, 335x10.5, Cool It Freezone cooler
Cooldbug @-5° :( with Single stage
http://valid.x86-secret.com/show_oc.php?id=400983
Athlon64 X2 6000+ @ 4121MHz 1.72v Vapochill @ -10'c WR Link
Secret stepping :)
here is my overclock from my athlon 64 x2 5600+
vcore = 1.475
settings= 12X 271 = 3252 mhz
idle 30 degrees stressed 40 degrees (23 degrees amb and on water)
http://img404.imageshack.us/my.php?i...aamloospw0.jpg
i also tested is stable whit orthos for more than half an hour...
still thinking if i am gonna puch the vcore up to 1.5 and get another few mhz out of it... (has to be pretty stable and it can't die on me for another few months)
Here is my most recent overclock
CPU: AMD Athlon 64 x2 5400+ B.E.
vcore: 1.385 in BIOS / 1.28 in CPU-Z
multi: 15
Bus Speed: 215
15x215=3225 mhz
Temps: 27C idle and 38C load (on water)
http://valid.x86-secret.com/show_oc.php?id=436500
Tested with f@h for 24 hours
AMD Athlon 64 X 2 4450e @2.76 Ghz stock HSF
Vcore@1.232
11.5 multi
Idle temps 32*C Load ~48-50*C
B2 stepping....
Running on a Biostar TA780G M2+
2GB OCZ DDR2-800 @ 460Mhz
5-5-5-15
Minor OC (all stock voltages)
http://valid.x86-secret.com/show_oc.php?id=436786
X2 6000+ WInsor F3 | 3600 Mhz @ 1,456V primestable!
http://www.abload.de/thumb/3600fertig02h.jpg
Been fiddling around with my new mobo and here's what I've got from my 5000+BE. Completely stable with Vista64 and runing prime64 bit also. Managed to get a bump of 100MHz from changing from m3a32-mvp. Idle temp 31ºC, load 58ºC.
Air cooling Thermalright SP-128SE
http://valid.x86-secret.com/show_oc.php?id=445030
http://img219.imageshack.us/img219/4774/ockc3.png
X2 6000+ Brisbane @ 1,45v
http://valid.x86-secret.com/show_oc.php?id=439804
my 5000+ BE @ 3.3ghz.
not prime stable, did load programs no problem however. that's the most it went through. fresh install of vista SP1
neeeever booted @ 3.3 again :shrug:
time is off...i farked on setting it. had to reset cmos before because my 'wonderful' dual bios didn't recover.
will try again this weekend
http://img196.imagevenue.com/loc59/t...z_122_59lo.jpg
hopefully i can post this here too? even though it's not X2,
didn't see a thread for single core
i got bored last night and went after my s754
Athlon64 s754 2800+ 1.8Ghz stock
munching down on 1.70v w/ stock HSF
it booted @ 1.650v and passed a superpi (only bench it could run) but locked after 10 min.
board doesn't let me do 1.675v :S
Win2K for the O/S
http://img245.imagevenue.com/loc22/t...z_122_22lo.jpg
X2 4050e @ 1.47V
http://valid.canardpc.com/show_oc.php?id=456180
wow.. are those volts even safe? i didn't wanna try for 1.43 and above cos i was afraid of burning up my 3600 brisbane.. maybe that's why i'm limited at 2.8ghz lol
Athlon X2 4850e DH-G2, 3 GHz @ 1.35V, Prime stable. :yepp:
Athlon 64 x2 5600+ @ 3.50 GHz, 1.456V
http://img262.imageshack.us/img262/2303/oc1vq9.th.jpg
http://valid.canardpc.com/show_oc.php?id=465209
