CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 3, Stepping: 2
Extended CPUID: Family: F, Model: 23, Stepping: 2
CPUID String: 20F32
Processor APIC: 0
Processor: Dual Core AMD Opteron 165 (Toledo)
CPU Speed: 3033 (337 x 9.0)
Revision: JH-E6
Platform: Socket 939
Startup VCore: 1.350v
Maximum Case Temperature = 59C
TDP: 85.0 Watts
.:a BEAST:.
no wonder it does 2.9 at stock voltage :)
latest screenshot 336x9 1.57v
http://weboperative.com/gallery/qdig...per-166ram.png
Hey guys, I have a question regarding my temps and overclock.
TCase Max (v1.19) shows that tcasemax is 59°C (fx60).
Is this is the same temp as reported by Everest for cpu (not the cpu0 and cpu1)? I've looked through many forums and topics, however - just want to make sure I understood things right *or wrong :)
You can see all the info on attached screenshot (also ran orthos 17hours+ stable, please note my temps in everest - are they ok?)
http://img184.imageshack.us/img184/7...uidina8.th.jpg
My question would be - should I push the cpu a lil further (also raise voltage a bit)? Or temps are already high enough, and I should go for better cooling first?
p.s. orthos ran was made in a hot summer day, I think room temp was ~25°C
thx
