Morning :)
are these 2x512mb >
corsair CMX512-3200xlpt
Xms3208v1.2
0447071-1
PCB says BP MLL E186401
Doing 250 5-3-3-2 @ 2.8v in p4 rig so i guess maybe they are :toast:
Morning :)
are these 2x512mb >
Xms3208v1.2
0447071-1
thats what i have, 2x256mb, and those model numbers.. id say yes they are..
Same mem as I have, its TCCD chips build on Brainpower PCB :rolleyes:Quote:
Originally Posted by stestan
Lets see some results ;)
I am having same problems as you with my ATHLON64 setup
Just been playing and cant get over 240fsb on my gigabyte mobo :stick:
Does 235x10 (ddr470) 2.6v and 6-2-3-2 but cant touch 240x10 even with 8-4-4-2.5/3:confused: 1x512 or 2x512
And if i try 2.8v i just get bsods :stick:
Thing is i can run 1x256mb ch5 @ 262x11 @ 1-1 with 3.8v so mobo dont like 512mb stix i guess
On my p4 its @ ddr500 5-3-3-2 @ 2.8v gonna try more on the p4 :toast:
Twinmos twister 2 x 512m dual channel with tccd-chips.I tested them with cas 2 and tightened timings with a64tweaker and vmem max from bios (2,85V).DDR420 memtest ok,DDR440 memtest error...i will test DDR430 later and also with cas2,5 if i can hit ovet DDR500.....damn these chips are very hot :banana:
Wow 310! Great Job! :slobber:
What do you think is better? OCZ 3200 Rev2, Vitesta 600 or Geil UltraX 3200? ( 2x512 ) :D
Thx all & regards :toast:
Originally Posted by S!1v3rB@cK_Dk
ordered some myself @ 235 euro inc shipment , i'll post my results when i get em . Mind you i'm on nforce² so it might not be the kind of results your interested in =] . God i hope i'm getting a pair of voltloving puppies.
Anyone know if the two PQI Turbo 3200 revisions DPU and DBU use the same revision of BP PCB? It seems the platinums are a bit cheaper but is that just because the black may appear more uber to some ppl? :confused:
hi all
did anyone try one of the following types of memory allready?
512MB x 2 (1GB) PC3200 DDR, CL2.5 (Corsair, TWINX1024-4400C25PT) <-- 256 euro
or
512MB x 2 (1GB) PC3200 DDR, CL2.5 (Corsair, TWINX1024-4400C25) <-- 258 euro
this is supposed to be very good tccd brainpower pcb ram too...
http://www.anandtech.com/memory/showdoc.aspx?i=2312
a very nice review from anand
offcourse its very possible anand got handpicked ram,
so i was wondering if others have this ram and what u think about it?
atm im doubting between these ram:
512MB x 2 (1GB) PC3200 DDR, CL2.5 (Corsair, TWINX1024-4400C25PT) --> 256 euro
2x512MB DDR RAM Corsair TWINX1024-3200XLPT --> 237 euro
2x512MB DDR RAM G.Skill PC4400@2.5-4-4 Extreme Series Dual Channel --> 247 euro
2x512MB DDR RAM GeIL Ultra X GLX1GB3200DC --> 249 euro
2x512MB DDR RAM Kingston HyperX KHX3200UL --> 220 euro
all these should be tccd
i dont want other gskill, only their cheapest fits in my budget, rest is too expensive (270,280,300 euro)
i wanted to use it with a winchester and an nforce 4 ultra (dfi?)
is that cheap kingston hyperx memory really tccd? and is it any good?
it has this code: KHX3200UlK2/1G, 1024MB 400MHz PC3200 DDR Non-ECC Ultra Low-Latency CL2 (2-2-2-5-1) DIMM (Kit of 2x512MB)
http://www.interngeheugen.com/prodmem.odb?artcod=31984
Guys, what's up with the huge price drop for OCZ rams? The 1GB kit PC4200EL Plat is going for US$205 at excaliberpc.com today. I got it for US$352 not too long ago! Another one is the PC3200 Rev2. My friend bought it for US$273 on 30 December and the price was US$205 a few days ago! Feeling sooo tempted to get another pair of PC4200EL Plat :D
guys ive been thinking...
i have the corsair 3200XLPT rev 1.2 TCCD 256*2 its currently running at 2.85V
i know there is a point where TCCD hates a certain voltage.. but id like to take my TCCD to 2.95V+ i would like to do the 3.3V cap mod.
to reduce the 3.3V cap mod voltage could i lower my 3.3V psu line? my psu has adjustable pots... thanks
ps, not sure if this is right thread?
Patriot 2*256 pc3200 xblk kit from newegg.
B6U815 Red HS
DFI Lanparty Pro 875B Rev A
P4 2.4C with Thermaltake SP94 HSF, default vcore.
275fsb 2.5-3-3-5 @ 2.6 vdimm and 1.5 vagp
400 passes of memtest #5. Priming at moment.
Im sure these sticks have more in them, but additional voltage increases haven't given me anything higher (thats stable).
Northbridge running extremely hot (passive cooled) so thats probably holding me back the most.
OMG, the OCZ PC4200EL Plat is now US$388! :eek:
is that expensive? srry dont live in USA
bah after having my PDP xbl for about month and a half, and wondering why it wouldnt go above about 260 with 2.5-3-3-7 with low voltage. wanted to get to the bottom of it. although i should have done this the first day i got the ram, i just didnt :p ram memtest on both sticks @ 285 2.5-3-3-7 2.85 1 passed until i stopped, other started getting errors in 3rd pass of test #5. RMA and hope to get 2 sticks like the good one i had :/
then put the "good" stick at 300mhz with 2.5-3-3-7 2.85v and didnt crash after about an hour of just doing random stuff (yes i know that doesnt mean its stable) then took em out to send back.
again this memory is mentioned for its good performance, this time by xbitlabsQuote:
http://www.xbitlabs.com/articles/mai...epox-9npa.html
In the 8x300MHz mode the frequency of the HyperTransport bus was 900MHz (3x300MHz), and the memory was clocked at 600MHz (2.4GHz / 8). The memory timings were set to 2.5-4-4-8. By the way, among the memory modules we had at hand during our tests, only Corsair CMX512-4400C25PT could work that fast (as DDR600 SDRAM).
can anyone confirm if non-picked samples of these memory are so good too?
cause then they are alot cheaper then ocz rev2 or the better gskill sticks (259 euro <--> 280/300 euro)
allthough i still think thats too expensive for me, i might still give em try of they are really that awesome...
Could you post "SPD" CPU-Z screen of each stick please?Quote:
Originally Posted by computersmsa
Got myself some G.Skill PC4800LA (440)
Running quite nice in DC:
http://www.hardwaredome.nl/images/re...kill311285.JPG
311MHz CL2,5-3-3-6 1T @ 2.85v Pifast stable @ low cpu MHz (2800)
http://www.hardwaredome.nl/images/re...ill290260s.JPG
290MHz CL2,5-3-3-6 1T @ 2.60v Sisoft/Pifast stable CPU running @ 2900MHz
And the final pifast run with high cpu MHz
http://www.hardwaredome.nl/images/sy...ifast/3984.JPG
302MHz CL2,5-3-3-5 1T @ 2.9v with A64 Tweaker memtweaks and CPU @ 3020MHz :)
Nice DC results. :toast: Is that memtest & P95 stable too?
How do they do at 3.2v? Have you tried Cas 2.0 yet?
Hy guys!
I`ll get a MSI K8Neo2 and a 3000+. Still have to choose the RAM:
Which would you pick: (prices in brazil)
1) PC4400 GEIL 1GB ULTRA-X DUAL = $366
2) PC3200 CORSAIR 1GB TWIN XL PRO = $346
3) PC3200 CORSAIR 1GB TWIN XL = $315
4) PC4400 CORSAIR 1GB TWIN = $449
5) PC4400 OCZ 1GB DUAL GOLD = $389 (not sure if it is TCCD)
Thanks!
get the GeIL :)
Are these available anywhere in the US??? :confused:Quote:
Originally Posted by SynGroW
http://www.newegg.com/app/ViewProduc...220-009&depa=1
its a tccd mem ?
You need to add the Corsair Xpert, @ Anandtech they said its TCCD or I dont remmember where but someone sure did. :)
Sure! New Egg has the 2x256 kit (F1-3200DSU2-512LA) ...Quote:
Originally Posted by rpr
... and Digi4Me has the single 256mb stick (F1-3200DSU1-256LA)
http://www.newegg.com/app/ViewProductDesc.asp?description=20-220-009&depa=1[/url]
Nope. At least not the newer TCCD that love voltage. You need the "XBLK" ... (PDC1G3200+XBLK)Quote:
Originally Posted by cupra
