ReelFiles, and what cpu cooler do you use?
but where is it? i can see only a big radiator and no fan on it...Quote:
Its Tuniq. Fan is INSIDE big radiator.Quote:
Originally Posted by L'enFer
It's a Tuniq Tower 120, the fan is in the center of the heat sink.Quote:
http://i67.photobucket.com/albums/h2...toniqtower.jpg
thanx, now i see...
Originally Posted by BlaqMale
No it can't.
asus p5b-3
c2d 6400@ 3200mhz w/ zalman 9500 led hsf
evga 7900gs w/ valman vf700 gpu cooler
320gb seagate 7500.10 sataII
120gb WD cavier IDE
Philips DVD R/RW
2gb Wintec amp-x pc 5400
600w psu
Atrix case
http://img.photobucket.com/albums/v1...in00/tower.jpg
the wires at the bottom are for the fans
http://img.photobucket.com/albums/v1...n00/tower1.jpg
http://img.photobucket.com/albums/v1...n00/tower2.jpg
the side when running. open air case thats just one big filter. the multi color is from the 120mm fan that has 4 different leds. need to change that up to just blue
http://img.photobucket.com/albums/v1...n00/tower3.jpg
Almost current rig, only I had the 7800GTs in SLI for the x1950pro:
http://img163.imageshack.us/img163/5...istebb9.th.jpg
Thats with the jigsaw-modded 120mm blowhole, sheesh that was fun!
my home server, today i got some time and re-did the wiring and remounted the HS, it dropped the temps 8C lol
http://www.xtremesystems.org/forums/...1&d=1168453359
btw, if the pics are too big, let me know, ill resamle them
Nice clean setup you have there Serious1 :clap: :clap:
Thanks:). Did you ever get the Big Typhoon installed? I found some stuff I can mail you that will work.
Parts came in....just trying to get some free time to Git R Done.Quote:
Originally Posted by serious1
OK, that's great:). Be sure to post some pictures when it's done;).
Will do ;)
Here is an old pic:
http://i5.photobucket.com/albums/y19...d/IMG_4575.jpg
Modded SI-97 non "A" on non-IHS'd sempy 2600+, with gutted Silencer and 70MM Fortron 70MM fan for 9800Pro running 450/365
bryan d
Done!!.....:DQuote:
http://img172.imageshack.us/img172/3...2004ga9.th.jpg
Looks nice:). BTW: Will the Dominator memory fan work with any type of memory like my Ballistix?
this is my new system R @ P T O R 2
Attachment 54768
Attachment 54769
Attachment 54770
Attachment 54771
Attachment 54772
It should,It clips onto the side of the mem slots.Quote:
I would say theres at least an inch or so of clearnce underneath;)
^^ Maybe I should invest in one since I can't seem to find the OCZ one anywhere? Is it really quiet?
They are running at 5500 rpm, I dont even hear them...:woot:Quote:
MMM soo quiet.
Scythe 800rpm intake/exhaust and undervolted silverstone fm-92/82 fans.
Thinking of ditching the intake and the small fan on the vid card and instead stick a scythe blowing over it.
http://i51.photobucket.com/albums/f3...524/misc/2.jpg
http://i51.photobucket.com/albums/f3...4/misc/1-1.jpg
You use the HR03 passively on your 1950XT..? What are your temps with it?
