Thank you M8.............. :D :toast:Quote:
Originally posted by Dagalidis
A BIG HELLO to Hipro5.... :toast:
Just continue your GOOD JOB my friend.... ;)
.....and WELCOME to the Xtremes........ :toast:
Hey Hipro5... What'd you say, R404 mach1 or mach2?
Mach II of corse.....Better "head" design........ ;)Quote:
But the cooling performance is the same..:toast:
If in System Properties you set the computer to ACPI instead of 'multiprocessor .....' then WCPUID should update frequency.Quote:
Originally posted by Tom Holck
Give me some time to beat you:D :D
But mine 4366 is made by booting to the desktop!! My softfsb work, but do'nt upgrade the clock and the wcpuid ?
However this also disables HTT.
For nice looking screenshot this is just fine ofcourse.. :D
Please tell me how can run PI Fast when overclocked because it dont let me start the bech due to Overclocked CPU.....
This is not a fault from an unstable system but a warning from the app....
:mad: :mad:
You just "clik" on pi-fast(.bat) which is 1K and the bench starts itself......
Well, I've been on a benchmarking hiatus recently heh, but I'm back and this is just the start :P
My 2.4C, P4P800 DLX, and new XMS3500. Everything is stock thus far.
1.600v on the core, aircooled. This would make the 3rd best aircooled score I believe on the pifast scoreboards.
I LIKE THIS BOARD! :) It seems to be giving me 5mhz fsb more stability than my 8KNXP @ stock. Another thing I'm noticing bout my setup, this chip doesn't like voltages over 1.600 on aircooling. It refuses to boot into windows @ 1.675, almost makes it @ 1.65 and 1.6250 works (but it gives me like 1.6v actually).
Anyway, I'm happy. I will be hooking up better cooling later ;)
http://www.maximumoc.com/img/hardwar...mhz_pifast.png
Also, yeah it's not stable but oo it's purdy to look at.
http://www.maximumoc.com/img/hardwar...mhz_setfsb.png
Here my personal best....57.30secs with 4.1 ...NOT v4.2
It does Superpi 1M in 40secs...
Epox 8RDA vdd modded
A Tbred @ 2480Mhz 11x225Mhz DC 2.0 2-2-11
Not bad for under 2.5Ghz ;)
http://129.125.103.64/pifast5730.JPG
Well I just got my prommy, and the 1700+ 0319 is doing ok so far...
http://home.comcast.net/~gpl08/Pifast_55.78.bmp
2736 mhz... 210 x 13
Ok a little better after some more fiddling.....
2792 214x13
http://home.comcast.net/~gpl08/54.22...13_x214.77.bmp
Movin' on up.........:D
2823 mhz 13x217 @ 7-2-2-2
http://home.comcast.net/~gpl08/53.80...3__7-2-2-2.bmp
Great work muzz!!! :thumbsup:
Thanks brother Jeff.
Alot more to do yet, but I'm working on it...:D
BTW You didn't get yours yet?
Muzz can you give this 2.0 11-2-2 memory timing a try? Should be faster......
It's less intensive for the memory, but better scores?! Don't know why....but it works for me!
Nope... at the last second I just couldn't pull the trigger. :) Instead I bought a crap load of water stuff(which I still need for GPU/chipsets if/when I get a Prometeia) and a few other non-computer related things.Quote:
I did however pick up a nice little chiller unit... for free... :D
http://forums.teamphoenixrising.net/...threadid=15748
Again muzz... great job on the PiFast score... that just looks awesome!!! :toast:
That looks to me like you are going to have some fun Jeff!!
220v , I take it your using the clothes dryer plug..... heheh
GL with it mang, it'll make a great gpu chiller when your finished.
New score, but I'm running into the high fsb/high vcore problem on this NF7-S
2850 13x219 7-2-2-2
http://home.comcast.net/~gpl08/53.47...19_7-2-2-2.bmp
Thanks Again Jeff
Setting memory timings to 2.0-11-2-2 didn't improve my score.Quote:
Changing from 2.0-5-2-2 to 2.0-6-2-2 got my score just a tad better.
Best so far is 60.90 sec. @ 208*11,5= 2400Mhz
I'll pick up an slk800 saturday, hoping to get some speed out of my Xp2100. :)
By the way, nice score you got there NoStra :toast:
I did 11-2-2-2 on that first score, but for the score above 7 worked a bit better.Quote:
I'm obviously not done experimenting.........:D
still playing with it... I reckon if I get my cooling performance the way it should be, the 48 sec barrier can go. But I'm leaving on holiday so well... by the time I get back maybe the barrier is 47 :D
pifast 4.3 is out :)
http://numbers.computation.free.fr/C...ram/pifast.zip
version 4.3 makes a big difference
Last night I made this with version 4.1 nothing special by any stretch.
http://www34.pair.com/gleep/64.86.jpg
And this is today with the new version, same computer settings.
http://www34.pair.com/gleep/50.42.jpg
WTG JC !
Keep up the good work man, and have a good time on the holiday!
Pifast 4.1 is what everyone uses for the challenge, but thx for the heads up Gleep :toast:
I am still faster JC, with a higher multiplier. But I do reckon today's the last day and I think JC will be posting some great scores. JC, if you'd like you can borrow my vapo for that 9800 :) Let me know
Good work JC.......AND have a "cool" vacations......... ;) :D :toast:
