Realistically, on air how high can one go on memory clock while keeping TRDRD=4?
32M or maxmem?Some BBSE and PSC cand do trdrd=4 on air at 2712 mhz+ 32M ,higher for maxmem or valid.My samsung can do 2860 trdrd4 for a maxmem run but that\s about it,no stability from 2666+...
32M using Samsung D-rev or Hynix CFR/MFR.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
I dont think I can run 32m at 2800 trdrd4 with sammy, I dont think I can even boot.
These have to be some of the weakest PSC known to man. I had to use this much voltage for the 1.65v PSC profile!
http://i.imgur.com/sF7uaMV.jpg
damn, try 13 13 13 instead of 19 19 19 should be huge difference in speed
Testing a new set of 2666 c10's:
4900 uncore 2.15v
http://i.imgur.com/XzqBtfZ.png
4900 uncore 1.9v
http://i.imgur.com/tLZDf7d.png
1:1 @ 4Ghz 2.15v
http://i.imgur.com/1oIW1Qw.png
1:1 @ 4Ghz 1.9v
http://i.imgur.com/FV0NQ8H.png
Someone can try to instal 9.12 catalyst driver on mini board?
I've a strange issues, looks like the driver can't find the adapter. I've no problem since 9.4 and above 11.3.
I've try different bios official and unofficial and various s.o. xp-vista-7, but i can't figure out.
Got AsRock Z87 OC Formula and I'm really impressed how easy to overclock with it.
First try some PSC
http://i.piccy.info/i7/8d5643613c816...ot0017_800.jpghttp://i.piccy.info/a3/2013-09-18-15...00x500-r/i.gif
Seems will have a lot of fun with LN2 and this motherboard
Hello Gents, any recomendations regarding memory for this baby?
The Memory Support List is just evil :D
http://www.asrock.com/mb/Intel/Z87M%...la/?cat=Memory
PSC, Hynix, Samsung everything works fab man, this one of the most flex boards regarding RAM,... don't worry, just BBSE are a bit harder to get properly working...
Some GSkill 2200CL7 runs on W7x64 CPU water MEM air
http://i.imgur.com/IrkCMeI.jpg
2600CL7-12-7-28 1T@ 1.9V
http://i.imgur.com/fDeeyk3.png
Cheers !!!
Sergio
i am back again ! ... was too busy last weeks .!!
:up:
I need to tweak this but its a start
4770K 5GHz 2600CL7-12-7-28 1T@ 1.9V SPI32
CPU Water TT Extreme MEM Air
http://i.imgur.com/dl8FFoN.png
Cheers !
Sergio
@andress: getting there mate. Just a bit more tweak on the tCWL and tRDRD will boost more. :)
Thank you :up:
+0.25 on System Agent did the trick :D
I got to get one of these new boards, I loved the OC formula and this seems perhaps a touch better yet.
