sorry i meant 5.1ghz.
Before i was bumping off of 100-104C....
now 62-63C.
I can now do INtel Burn Test at 4.9Ghz @ 1.344Vcore
now 62-63C.
Yes i know as we have same temp here but what im telling considering the methods most ppl that are here live in cold places, i have the liquid pro here and very doubtful to aply it cauz im afraid all the job for nothing...
u can leave it rock solid at 1,325 BIOS with ULTRA HIGH LLC at 4.8HT i tested your batch or use OFFSET wich is better at +0.115 ;) try it and report back
Thanks to you for the reply
Cheers
Sergio
The results i have seen dont lie. If I run the same before and after. I see a measured 40C temperature drop with the same Vcore and speed.I picked up only a few extra Mhz, but was able to do it at lower voltage.
Well after all guys i have to tell you that i resisted to use liquid ultra cauz basically i though it was the same as using MX2 or MX4 or whatever tim
i want to thank hersounds, C-N, Zeus, kirbster1966 and all the guys who answered my questions and show me the method
Today i couldnt belive my eyes really i even remounted CPU cauz i tought somthing was not ok
ALL TESTS SAME AMBIENT TEMP
http://i.imgur.com/A8i1j.jpg
this is the BEFORE with IHS removed and using MX2 at 4.6HT@ 1.336 LOAD and 2800CL11 mem
http://i.imgur.com/wpzeA.jpg
this is the AFTER with IHS removed second time with liquid ultra at 4.8HT 1.360 LOAD and 2800CL11mem
running...
http://i.imgur.com/tLDyu.jpg
passed...
http://i.imgur.com/egjZX.jpg
U can see the amazing drop on temps i just cant believe it but its true
And here the process
chip with MX2 inside and out
http://i.imgur.com/bTnoK.jpg
IHS removed it was already loose
http://i.imgur.com/2wYNU.jpg
ALL Cleaned ready to take the new liquid ultra
http://i.imgur.com/s2AxO.jpg
http://i.imgur.com/oypDw.jpg
Starting the job with liquid...
http://i.imgur.com/mJZAO.jpg
Finished :) CPU glued with light UHU cement on 2 points only just to make easy the mount inside case without taking mobo appart
http://i.imgur.com/6pTbE.jpg
some more pics for fun :)
http://i.imgur.com/BFWlj.jpg
http://i.imgur.com/13TyE.jpg
hope you guys like and benchers go ahead use this its so amazing :yepp:
REAL WORLD aint this amazing ? :up:
http://i.imgur.com/Kc8BK.png
I know, in a hobby where we like to think a 5C temperature drop is a victory, 40C is just crazy!
Awsome sergio
Good work my friend as i say Phoebya LM was the way!
and relax! the temps drops even a little more with days and weeks of use....don't care for that, just think that you and me ( Argentina/ Uruguay ) we're starting fight with hot days ,is spring and summer is coming
Hate to say it but i told you so. :D Liquid metal is the way to go mate. Totally awesome result but did you use a flexible adhesive?
If you can show me something 3Dmark vantage ...... at 5.1 or 5.2GHz then you can also get me to play with my cpu andressergio
Can you tell me if before this MOD you could run at 5Ghz ?
Or what was your max bootable clock at before the MOD ?
yeah this is a 3218B one of the best batches i ever seen but i always mod my IVY
first i tried no mod but temps where hi
then modded with MX2 but after a month temps returned high again
so...
i decided to to what you saw and im still shocked :)
u just need a good batch to be stable at 5Ghz HT and of course this mod with this liquid with help you man its 40C its like unthinkable but true :)
Cheers man
Sergio
Thank you.
I asked that because i cant boot at 5ghz cooled with H80 corsair.
And was thinking, maybe doig this mod it would do 5ghz ... not sure.
Look at this guys i
i had more images to show but i lost my raid :(
i was primming at 55C all the time max at 56C
now today its almost 27C on my room and look this :)
http://i.imgur.com/leFfa.jpg
5GHz HT offset +0.195
http://i.imgur.com/E43m7.jpg
Stop posting these...we're increasing humidity in our places with drooling...:p:
Hey guys becareful with Vcore seriously go 24/7 more that 1.30 can degrade your Ivy really...
- don't use more 1.30 vcore for 24/7
- don't use more 1.30 VCCSA
- don't use more 1.30 VCCIO
- use CPU PLL as low as possible
And you have a healthy Ivy ready for bench when you want.
On topic: before IHS mod i can use 5 Ghz but need more vcore and temps are highs...now two weeks beyond of ihs mod. I can use 5.0 Ghz with 1.40 vcore
