hmmm it depends .... with my case (lian li) i can reduce cpu-temp by cooling the space between Motherboard and MB holder/plate (cpu temp is ~4° lower) ... core temp (of course) isn't affected.
so i think you need to know both of them ...
Wich makes it totally useless. Core temp would be more comparable then. Even if its off, its off by the same amount for everyone, right?
Is anyone using an Asus M4A89GTD PRO with their 1055T ? I cant get any higher clocks than turbo mode clocks, any higher and it becomes very unstable , programs crash and graphical corruptions occur often, but it passes LinX and Prime95, how does that work?
Im sure Im just getting a basic bios setting very wrong so if anyone has this mobo and would like to share settings it would be greatly appreciated.
:up:
* CPU Model: AMD Phenom II X6 1090T
* CPU Stepping:
* CPU Frequency: 4014 MHz
* CPU vCore: 1.5125v bios (full load in 1.454-1.464; idle 1.488 cpuz)
* CPU NB Voltage: 1.225v
* CPU Multiplier: 20x
* CPU Turbo: Disabled
* CPU NB Speed: 2812 MHz
* HT Ref Speed: 200 MHz
* RAM Speed: DDR3-1600
* RAM Timings: 8-8-8-24-2T
* RAM Configuration: 2 x 2GB
* RAM vDIMM: 1.59V
* Motherboard: ASUS M4A88TD-V EVO/USB3
* Chipset/Socket: 880G + SB850, AM3
* Cooling: Water - EK Supreme HF/ swiftech 3x120 QP rad
* Temps: 34C Idle / 45C Load
* Operating System: Windows 7
* 32/64-Bit: 64
* Stable/Suicide/Untested: Stable (1h occt)
others: CPU and CPU/NB load line calibration is disabled; room temp 28-29 Celsius
http://a.imageshack.us/img838/4871/occt.jpg
You have to run an 8hrs bench to proove stability.
P.S thats a very :banana::banana::banana:gy wallpaper
I'll have to mark you as untested for now. We need eight hours. That's a HUGE SS, btw. :) Kind of looking to get into it myself, but I was thinking more like 1/4 HP. Fortunately my dad is an HVAC guy, so parts shouldn't be too bad. There's a lot of scrapped stuff out behind his shop.
How long did 500 passes take? In any case, I'll need a screenshot of eight hours.
Please run for eight hours if you want to be marked as stable.
Charts updated.
sorry bout that will post 8 hour test later.
comments like this is unnecessary. That's derogatoryQuote:
i highly doubt that OCCT tests are 100% stable
on my rig it takes up a mere 1.9gb of RAM in total and temps rarely hit 40C coretemp
LINX with mem set to ALL on the other hand eats up 7.8gb without other tests running; cpu temp is by over 17°C higher and my highest 4hr stable OC is 250 mhz lower (!)
will post my results tomorrow; for now i have an untested entry:
* CPU Model: AMD Phenom II X6 1055T
* CPU Stepping: none^^
* CPU Frequency: 3913 MHz
* CPU vCore: 1.46V
* CPU Multiplier: 13x
* CPU NB Speed: 3000 MHz
* HT Ref Speed: 300 MHz
* RAM Speed: DDR3-1605
* RAM Timings: 7-8-7-24-2T
* RAM Configuration: 8 GB (4 x 2 GB)
* RAM vDIMM: 1.65V
* Motherboard: ASUS Crosshair IV Formula
* Chipset/Socket: AM3, 890FX + SB850
* Cooling: Water Dual Rad
* Temps: 30C Idle / 66C Load
* 32/64-Bit: 64
* Stable/Suicide/Untested: 4hr LINX All memory (7160MB)
Only got a shot of 20 Linx Passes; will update once i have 8hr Linx
*snip uploaded max HTT screenshot...*
lost my 4hr screenshot; unvalidated 20 mins:
http://www.abload.de/thumb/oc5ua8h.png
• CPU Frequency: 3744 MHz
• CPU vCore: 1.4V
• CPU Multiplier: 13x
• CPU Turbo: Disabled
• CPU NB Speed: 2880 MHz
• HT Ref Speed: 288 MHz
• RAM Speed: DDR3-1535
• RAM Timings: 6-7-6-20-1T
• RAM Configuration: 4 GB (2 x 2 GB)
• RAM vDIMM: 1.53V
• Motherboard: Gigabyte GA-890GPA-UD3H (Rev2.0, FD BIOS)
• Chipset/Socket: AM3, 890GX + SB850
• Cooling: Noctua NH-D14
• Temps: Not calibrated
• Operating System: Windows 7 Ultimate
• 32/64-Bit: 64
• Stable/Suicide/Untested: Stable
Other relevant info:
HT Link clock: 2304 MHz
CPU NB voltage: 1.325V
CPU-NB is very important, as Anandtech showcased here: http://www.anandtech.com/show/3877/a...ance-scaling/7
Stock CPU NB voltage won't get very far (under 2500). Check out my blog post for other insights on the whole overclocking process:
http://techonnapkins.wordpress.com/2...curious-about/
- CPU Model: AMD Phenom II X6 1090T BE
- CPU Stepping: CCBBE CB 1023GPMW
- CPU Frequency: 4013 MHz
- CPU vCore: 1.404V
- CPU Multiplier: 20x
- CPU Turbo: Disabled
- CPU NB Speed: 2800 MHz
- HT Ref Speed: 200 MHz
- RAM Speed: DDR3-1600
- RAM Timings: 7-6-6-18-24-1T
- RAM Configuration: 8 GB (4 x 2 GB)
- RAM vDIMM: 1.875V
- Motherboard: ASUS Crosshair IV
- Chipset/Socket: AM3, 890FX + SB850
- Cooling: Air (Venomous X RT w/ 2x YL D12SH)
- Temps: 33C Idle / 52C Load
- Operating System: Windows 7
- 32/64-Bit: 64
- Stable/Suicide/Untested: Stable
http://valid.canardpc.com/cache/banner/1382330.png
did this while testing the 055 bios, figured no reason not to submit it. but anyways there is a +10c offset I added into the configuration of coretemp to match the cpu temp in bios and other apps.
http://www.boss-gamers.com/files/pictures/1090-p95.png
oops - didnt see this thread!
Not many 8gb clocks on here - but heres my effort on a Corsair H50-1 - twas 24 hour prime stable :) :)
http://i1022.photobucket.com/albums/...NB142v_12v.jpg
* CPU Model: AMD Phenom II X6 1090T BE
* CPU Stepping: Unsure sorry
* CPU Frequency: 4013 MHz
* CPU vCore: 1.425V in BIOS - with LLC up to 1.46v
* CPU NB Speed: 2400 MHz
* RAM Timings: 8-8-8-24-41-2T (stock settings)
* RAM vDIMM: 1.65V
* Motherboard: ASUS M4A89GTDPRo/USB3
* Chipset/Socket: AM3, 890GX
* Cooling: Corsair H50-1 Push/pull config
* Temps: 35C Idle / 60C Load
* 32/64-Bit: 64
I will state though to be honest - As bioses have progressed so has the stability of my overclock - it seems to have got worse - Have had to reduce my CPU-NB to 2200Mhz for 24hour prime blend stability.
Currently trying to get 250x16 stable with 2500CPU-NB - wierd that prime seems to stay up well for 6+hours but playing BFBC2 for 10minutes crashes! - working on it and will report back ;)
something I would have found really handy for reference is CPU-NB volts - mine is 1.2v would love to have seen others ;)
Rock and roll. The charts have been updated.
* CPU Stepping: CCBBE CB 1013CPAW
* CPU Frequency: 3808 MHz
* CPU vCore: 1.392V
* CPU Multiplier: 14x
* CPU NB Speed: 2176 MHz
* HT Link Speed: 2176 MHz
* RAM Speed: DDR2-1066
* RAM Timings: 5-5-5-15-2T
* RAM vDIMM: 2.2V
* Motherboard: Gigabyte MA790X-UD4P
* Chipset/Socket: 790X + SB750, AM3
* Cooling: Air (Mugen2 w/ Scythe S-Flex 1600rpm)
* Temps: 16C Idle / 47C Load
* 32/64-Bit: 64bit
* Stable/Suicide/Untested: Stable more than 90 hours of LinX 0.6.4
http://i30.photobucket.com/albums/c3...to_1/AMDX6.jpg
:confused: After 3 days the Progress bar went funny and it switched over too all minutes... dont know what went wrong there probly a bug.
* CPU Stepping: CCBBE CB 1024DPMW
* CPU Frequency: 4004 MHz
* CPU vCore: 1.475V
* CPU NB Speed: 2772 MHz
* HT Link Speed: 2155 MHz
* RAM Speed: DDR3-1640
* RAM Timings: 6-8-6-22-1T
* RAM vDIMM: 1.6V
* Motherboard: Gigabyte GA870A-UD3
* Chipset/Socket: 870 + SB850, AM3
* Cooling: Air (Noctua CH-12P SE14/ Thermaltake 2000rpm)
* Temps: 21C Idle / 50C Load
* 32/64-Bit: 64bit
* Stable/Suicide/Untested: Stable more than 1 hours of OCCT
http://img408.imageshack.us/img408/6955/daily4.jpg
Adios
I'd run prime for 8 hours but this thing uses over 1.5kilowatts per hour :P, i've got 4.7ghz stable.
For cascade users there should be a exceeption :P, sif be running 300watts of heat into the cascade for 8 hours straight :P, i reckon 1 hour stability test should be valid, cause i can play BC2 at 1980 res with everything on high for 10 hours straight with out a crash or problem.
I must say though, you've done a good job with the charts :)
CPU Model: AMD Phenom II X6 1055T (125W)
CPU Stepping: -unknown-
CPU Frequency: 3808 Mhz
CPU vCore: 1.478V (Bios), 1.55 (load,CPU-Z)
CPU Multiplier: 14x
CPU Turbo: Disabled
HT Link Speed: 1904 MHz
RAM Speed: DDR2-800
RAM Timings: 5-4-4-16 2T
RAM vDIMM: stock
Motherboard: MSI 790XT-G45
Chipset/Socket: AM2, 790X + SB710
Cooling: Air (Thermolab BARAM, 2xSlipstream 1200rpm Push-Pull)
Temps: Core: 26 idle/40 load || CPU: 40/55
Operating System: Windows 7 Ultim.
32/64-Bit: 64
Stable/Suicide/Untested: Untested (InterlBurnTest, 5 Passes. P95 still going)
http://img340.imageshack.us/img340/8448/x6105538ibt.jpg
whats the default CPU-NB vcore of a 1090T ? mine defaults to 1.36v CHIII with 1805 bios ( forget that just noticed it defaulted to 1.15 ish after a reset my bad )
only had it a day , not played yet but have ran 3dmark 06 @ 4.2gz ok 1.45v 24,660 points
cheers
My new CPU ;)
batch 00001
http://img831.imageshack.us/img831/5331/1222v.jpg
wow nice memel.
lol, number 1, lucky man :)
http://i1022.photobucket.com/albums/.../4ghz_2600.jpg
* CPU Frequency: 4013 / 4045 MHz
* CPU NB Speed: 2600 MHz
* RAM vDIMM: 1.65V
* Cooling: Corsair H50-1 Push/pull config with 2 x Akasa Apache
* Temps: 35C Idle / 59C Load
* 32/64-Bit: 64
Extra 200Mhz on CPU/NB by upping VDDA to 2.6 and CPU/NB volts to 1.275v - New 24/7 stable overclock :)
Good thing I took the "untested" label to heart: after 50 or so runs of Intel Burn Test, I ran into an error. I dropped the HT Ref by 1 MHz and now have run two nights in a row without error. Here are the final stable settings:
• CPU Frequency: 3731 MHz
• CPU vCore: 1.4V
• CPU NB Speed: 2870 MHz
• HT Ref Speed: 287 MHz
• RAM Speed: DDR3-1529
• RAM vDIMM: 1.53V
• 32/64-Bit: 64
• Stable/Suicide/Untested: Stable (500 runs of Intel Burn Test)
BTW, I tried a 13.5 and 14x multiplier (3.87 and 4.01, respectively) with higher voltages, but I would have taken 1.45 and 1.50 respectively to stabilize, and the power draw/heat increase was too severe. I didn't run full overnight tests at these settings, as it was more just for curiosity's sake.
http://img580.imageshack.us/img580/1...loverclock.jpg
Update: Posted pic. Note that C'n'Q is enabled.... you're not going to get 71GFlops from 1.1GHz :P
Also, CPU-NB voltage was 1.325V, as mentioned in my last post.
SergeantNathan, I have no reason to doubt you so I'm going to put you as stable, but do you have a screen shot? I won't be able to leave it that way without the same level of proof I've required of everyone else. Glad to hear it though. :)
Charts are up to date.
