I have the exact same issue, I can run up to 4.3 at like ~1.3v, but once I pass that I'm looking at 1.4-1.5v. I can't say that it's normal, but at the very least expected heh.
@ lOud_sil3nc3-I have an i7-960 that runs 4.0ghz stable on stock vcore, but cannot get it stable at 4.5ghz for the life of me HT on or off. I hate that chip!!! Guess some are just weird that way.
Inching my way past my previous best.
http://i39.photobucket.com/albums/e1...n/linX4574.jpg
i7 920 D0 @ 216x21 = 4536mhz
HT on, EIST on, VM on, everything but C1 on basically.
mobo is a x58a-ud7 with EK FC block in the cpu water loop on bios F6
Running around 1.4v cpu on bios but it's about 1.36v in cpuz.
Watercooled setup:
apogee gtz
Indigo Xtreme
2x mcr320 with 9 gentle typhoon 1850rpm (3 on 1, 6 in push/pull on 2nd).
1x mcp655 + EK custom top
distilled water
Max temps are about 73c on 1st core.
There's also a similar loop on the 5970 (ek fc block, both rads are only 3 fans each, same pump/top combo).
http://img257.imageshack.us/img257/5...zlinx20.th.jpg
I'm considering pushing to 21x220 and see if I can do it with less than 1.4v... I'll keep you guys up-to-date ;)
Congrats antiacid - nice clock for such low vcore - also very nice temps!
Using 980x - was on F4 went to an F7 beta and then went back to F4 - I saw no improvement in my oc, actually f7 beta was a bit more finicy.
I like the wider v upswing in level 2 vdroop control in F4 vs the f7 beta i tried.
I'm at llc 1 and I didn't try any bioses past F6. I wonder if there would be voltage gains but I doubt it.
Right now I'm trying 220x21 and I'm playing around with voltages to make it stable for linx 20 pass. It passes between 3-6 times before BSOD'ing at 1.408 in cpu-z. I'm at 1.36 qpi/vtt and thinking of going to 1.38v.
Wondering if that'll help my qpi which is now 3960mhz (vs 3880ish at 216).
Also, I'm going to start using llc 2 because I was up to about 1.44 in bios and it still showed only 1.39-1.408 in cpu-z... It's just ridiculous.
On to testing!
http://img37.imageshack.us/img37/522/4620mhzlinx20.jpg
220x21 @ 1.41v :) (i7 920 3849B018)
Actually, this time around I ran with llc 2 therefore it shoots up to 1.42-1.44v in cpu-z during the linx 20 pass test.
I ended up getting my volts a bit higher too on the qpi/vtt: 1.38
Note that the temperatures are now 83-84c at max, which to me is unacceptable. I'm eventually going to re-mount when I get around to getting the case painted and that might help (the remount, not the paint lol) but until then, it looks like 4600+ is just too hot for my use.
some more volts of importance on my ud7:
pll: 1.8v
qpi/vtt: 1.38v
vcore: 1.425v (in bios)
dram: 1.64v
IOH core: 1.16v
Impressive 920 :up:
Got myself another chip to join the club with, just need to tweak it (testing IMC right now)
^^ I am stuck at just under 4.4ghz on this 960, cannot get 4500 stable. Have put the chip away several times out of frustration but keep reinstalling it to try again,I am about to give up on it. I will stick to lower priced CPU's, both my 920's will do 4500 stable with enough vcore and good cooling.
well I finally got 4.5 with HT on and cas 6
voltage and temps are high and I am in the process of lowering vcore and vtt
http://i49.tinypic.com/2uqiz3l.png
the reason for only 4GB and dual channel is I had to RMA some memory in my HTPC to Corsair so I had to rob a stick for it.
I still can't believe the DDR3 2000 c8 sticks I have can almost do DDR3 1600 6-6-6-18
Well guys
After some days of tweaking and finding out references on the MCH i can say im fully stable on a P45 board at 4500 / 2000 1T
http://img227.imageshack.us/img227/6...cr1pl8linx.png
Very happy with it
Cheers :toast:
Sergio
thats some nice stuff sergio now becnh :P
Damn you. 4500 mhz at 1.392v? On a 1.2000 VID chip? Mine is 1.1500 and takes almost 1.35 at 4.0 GHZ. What's going on? Maybe I'll just have to dedicate an entire day to tweak it below 1.3v where it should be at for its VID. You've probably seen my frustration in the other thread which I finally got stable from feeding it lots of volts but something just doesn't feel right.....
The only thing I could think of is my hard drive...it's the only thing I haven't upgraded in a long time...would this be causing the issue? It's an old Seagate Barracuda 160GB that I bought like 3 years ago and haven't bothered to upgrade cause I'm such a neat freak....I just suspect it and it probably isn't causing me the problem but you never know....I'm getting desperate now :mad:
im at 1,376 stable but for such pressure on the MCH and fast mem i need to notch vcore, same happened with my UD3P and Gskills PI1200
u can see here
http://img204.imageshack.us/i/45001600pl9turb0linx.png/
i also been through many horrible chips my friend and never got lucky until i start buying for know good OC batches and tested for some nice friends here its all a hazzle
dont go desperate if its bad just sell it and spot a good batch nr
Cheers mate all the luck for ya :up:
How come I only have 49 GFlops at 4.4 Ghz??? Not enough voltage?
