http://farm5.static.flickr.com/4039/...a3549fe6_o.jpg
DD 480 Nickel+Copper Full Cover Block
http://img526.imageshack.us/img526/7899/dsc1902.jpg
http://img291.imageshack.us/img291/8696/dsc1920s.jpg
EK-Supreme HF
http://img18.imageshack.us/img18/2610/eksupremehf.jpg
I don't believe there is a reservoir in that picture. If you're referring to the shiny plate above his graphics card, that's a LED lit plexiglas plate.
Supreme classic copper mod, full nickel:
https://www.dazmode.com/_Reviews/CPU...Lassic%204.jpg
Hi dazmode, nice to see you here, nice job on the nickel plated supreme hf. Does its possible to only get the mounting bracket nickel plated ?
Daz: Looks awesome there.
Thanks guys! This is not supreme HF. This is OLD Supreme block with custom plating.
@scgt1: i make the plates since ~ 2005 :) Itīs not very difficult. I can send you more pics, when you PN me your email addy.
@Dazmode: Nice to see you here Anatoly :)
http://www.abload.de/img/img_5581t0yj.jpg
http://www.abload.de/img/img_558900ed.jpg
bundy, now your just shilling, those pics are ripped straight from XSPC's site with some minor editing. :shakes:
Custom waterblocks
http://farm3.static.flickr.com/2477/...49823abd_b.jpg
http://farm4.static.flickr.com/3047/...492703d6_b.jpg
http://farm4.static.flickr.com/3506/...c7b6f360_b.jpg
http://farm3.static.flickr.com/2457/...bbcd530d_b.jpg
http://farm3.static.flickr.com/2474/...15d5f909_b.jpg
http://farm4.static.flickr.com/3318/...8a06a065_b.jpg
http://farm5.static.flickr.com/4059/...d1de37ea_b.jpg
http://farm5.static.flickr.com/4008/...813fe1c7_b.jpg
http://farm4.static.flickr.com/3380/...b97c5749_b.jpg
http://farm4.static.flickr.com/3565/...ae7c8f99_b.jpg
http://farm4.static.flickr.com/3662/...126654d4_b.jpg
http://farm3.static.flickr.com/2508/...c9c7e5cd_b.jpg
EK-GTX280
http://farm3.static.flickr.com/2421/...1d6bd2df_b.jpg
http://farm4.static.flickr.com/3363/...d539316c_b.jpg
http://farm5.static.flickr.com/4035/...39828f58_b.jpg
The first post says, Only Post Pictures you have taken Yourself. ;)
i thnik its clear that i took this one myself ;)
i think bentleya is reffering to bundy who posted the picture that Skinee took of the xspc gtx480 waterblock i am right ?
I thought I should post this here.
http://i572.photobucket.com/albums/s...m/P1010012.jpg
http://i572.photobucket.com/albums/s...m/P1010017.jpg
@psygnosi: what are those fitting size? 3/8" IN,1/2 OD" ?
Bitspower Black Sparkle Compression fittings 3/8"ID 1/2"OD from Performance PC.
