interestingly I found this.
http://www.intel.com/support/process.../CS-030850.htm
Seems this socket is very easy to damage such as dropping the cover in place instead of placing it carefully. I will inspect my socket as this intel guide says before I try to use it, and hopefully all my pins are fine before installation.
Is there a reason why pins are now in the socket instead of the processor? it seems the old system was much safer and robust to damage.
Can I ask how do I know if I have the revised socket? is it a certianty having brought a 2nd gen p55 board?
