heres where i bought mine from for 135 bucks.
good price, but Micro Center is very poorly rated over at http://www.resellerratings.com/seller3266.html
I have never used them...but thats a bpretty bad rating.....
So just ordered my DFI for 139euro. If anyone wants to buy a factory new Abit NF7-S 2.0 just pm me. That'll be 90euro !
New BIOS for DFI boards from OSKAR_WU :D
See here :http://forums.amdmb.com/showthread.php?threadid=290211
No info as to what changes were made .
EDIT : from readme file :
1 . Update OPTIMAL and AGGRESSIVE CPU interface define above 200 MHz
2 . Improve nVidia AGP card performance
3 . Improve APIC stability with all device turned on @ High overclocked FSB
4 . Increase AGP controller latency as 0FFh to improve 3DMark2001SE stability
Getting it now. WTG Oskar! :D
gunna test tomorow probly.. need to test new cpu first.
Sandra is about the same under the 1-21 BIOS compared to the 12-18.
My nVidia card does run more stably. 3dmark, well I've only done one run, it was a little slower under 1-21 than the 12-18 but that 12-18 3dmark run was pretty golden, plus I'd played around tuning the rig and haven't gotten very far with tuning on the 1-21.
I haven't tried to see how high the 1-21 lets me run yet either.
Overall, 1-21 looks like a contender :)
Where to get all these BIOSs ?
Umm scroll up 4 posts from yours.....:stick:Quote:
I don't want this version ..
Here ya go ;)
http://www.midnightmachine.com/modules/mydownloads/
Some of the Mosfets I think makes annoying "beeps". Not exactly beeps, dunno how to call it, it's more like "beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeee..." :D
Someone said that it could be a damaged mosfet, what u think of that, is my board damaged ? :(
I have this sound too, but only on this my 3rd board :confused:Quote:
But seems to run well though. Can't wait till my second khx3200 arrives. :)
One twinmos and the kingston together don't seem to perform optimally...
just got my Infinity today, 0347A1 northbirdge.
Which one is the last BIOS (beta or not) for Infinity ?!
default bios n stuff, right out of the box 225fsb.
1/21Quote:
What timings and that are you using?Quote:
Your int efficiency is only 94% and your float efficiency is only 89%, both of which are pretty low.
97/93 or even 98/94 should be your target before you start cranking the FSB ;) Low latency is king on Athlon setups, not bandwidth ;) Bandwidth is king for P4s ;)
Anyone found out what's the resistance value on that stock resistor (on the board)?
Is the other side of the stock resistor grounded?
Really Thanks dude!!Quote:
with the vcore mod i get random lockups etc... anyone have same problem?
Yeah. I think you should also post in the thread "Infinity/LP B vcore issue???" ... http://www.arcor.de/c/pub/extern.php...2&goto=newpost
I can see that most of you are running your timings at 2-2-2-11. Why not at 2-2-2-6? Can't the memory run that high FSB with those timings, or is 2-2-2-11 better?
11 is usually better. It's an anamoly on the nForce2 chipset.
and it only works with dual channel on nForce2.
