Hey mick,
Any news yet?
BTW, what size did you end up with on the case when adding the dual cpu mobo?
I ended up with 300mm W x 648mm H x 615 D (11.8"W x 25.5" H x 24.21" D) So far I have redesigned the case about 16 times since last October....man it was hard to get all the screw holes correct and to get everything to fit and where to mount stuff.
Im building the first one for a co-worker and he has two 360 Fessers (bottom compartment) so the need for 300mm wide was needed. I would need to go taller to fit a rad up top (top/bottom different sizes), about 7 mm, which I should have done (back to the drawing board to make them even)
Going this wide 300mm you should be able to fit dual rads up top and dual on the bottom....4 loops would be nice with the dual socket. Of course im using acrylic which is thicker material...:D
What did you find were the spec's for the dual socket mobo?
Here's a pic with it 60% done. (acrylic and aluminum angle)
http://i163.photobucket.com/albums/t...tter/011-3.jpg
